Question about Kenmore 62602 Electric Dryer
Wiring a 3 wire dryer wire into panel box
I have a 3 wire dryer and 3 wires at panel box. i know black is hot and white is hot, where do i wire the ground wire to? the neutral buse bar that has a big white wire that goes back towards meter or the grounded bus bar that is grounded to the ground?
  • asshole64 Oct 22, 2008
    now i'm wiring 3 wires into panel box. need to know if i hook up ground wire to neutral busebox with wire going back into meter or the grounded buse bar that is to the ground?
It doesnt matter if u put it under the ground or nuetral bus bar it will work and be safe either way!
Posted on Oct 22, 2008
    Scholar:
  • 147 Answers
Stick her under the neutral buse, the groung and the neutral are connect at the panel anyway.
  • butch welch Oct 23, 2008
    Thanks for the rating, but I did want to clarify something about neutrals and grounds. neutrals are neutrals and grounds are grounds. In a panel if a wire is on the neutral bar you assume it to be a neutral. If its on the ground bar you assume it to be a ground. You handle both with care. The difference being if you take a neutral from the bar and it is caring a load at the time it will become a hot wire (120 volts) and it has the potential to kill so always treat a neutral as a hot wire. Ground wire have no potential, so just keep the separated. The ground and the nuetral are bonded (connected) by the screws that hold the bar in the panel
I have a Leviton 5634 two rocker switch that I'm using to replace an old double switch that controls two lights. There are 1 black, 1 red, and 1 white wire in the light switch box. The white wire is...
Review old switches:
Two old switches > each has 2 wires
Old switch 1 > Red and White
Old switch 2 > Black and White
The same white wire connects to both switches, so effectively they count as 1 wire
This means you have 3 wires ... 1 White, 1 Red, 1 Black
Each switch controls a separate load (light, fan, motor)
New Leviton double-rocker switch:
-Leviton has 2 Brass-colored screws on one side, and these screws are connected together by a brass plate >> your Hot wire will connect to brass screw
-Leviton has 2 Silver-colored screws on other side, and neither of these screws are connected in any way >> the wires going to each load will connect on a different screw on this side of switch.
Hot wire: Each box in your house has exactly 1 hot wire that is connected back to breaker box. This is true for all boxes (excluding boxes that have a 3-way & 4-way switches).
We need to identify Hot wire.
-By code the Hot wire is black for identification purposes ... but your box sounds like maybe the Hot wire is White.
-If your Hot wire is white, that is NOT an immediate safety issue ... it will not cause a fire or malfunction ... it is a code violation ... because code requires things be uniform so next electrician knows what previous guy did. So some day, electrician working outside grabs wrong color wire, and wow. I say this so you know.
Moving on.
Identify Hot wire:
-Pull 3 wires up so they can be tested
-Turn on power
-Use ordinary tester, or old lamp with plug cut off and wires stripped back
-Tape tester lead to sticks so hands are away from voltage
-Power is on. Don't stand in water or touch metal pipes, and you're fine.
-You have 3 wires in box + ground wire
-Test all 3 wires to bare ground wire >> when tester lights up, that is Hot wire ... testing is complete
Connect wires to Leviton double-rocker:
-Power is OFF.
-You have 3 wires - 1 White, 1 Black, 1 Red >> one is Hot wire, the other two wires go to load
-Hot wire connects to Brass-colored screws on new Leviton.
-Brass colored screws are connected together by a brass plate so the Hot does not need to connect to both brass screws.
-The other two wires connect to Silver screws on other side of new Leviton switch
-One wire goes to each silver screw
-Connect bare ground wire to green screw.
-Push wires back into box. Use eraser end of pencil if needed.
-Make sure ground wire is back and away from screws on switch
-That's it.
Sep 30, 2010 | Leviton Electrical Supplies
Kenmore model 110 ele dryer has 3 wires giong into outlet but outlet is going to be connected to a 4 wire supply. red black white green which color is hot what color is ground how do i connect the...
This sounds like you should call an electrician, or someone that knows wiring. Red and Black are both hot, White is neutral, and Green is ground. Remove the ground strap from the center of the terminal block to the case. Put green wire to the case, white in the middle, and red or black to either side. Your last question I do not understand. But it sounds like you need an electrician to connect a 4 prong receptacle, with the proper 4 conductor wire to your breaker box.
Jan 01, 2010 | Kenmore Dryers
My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Oct 17, 2009 | Hardware & Accessories
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
May 23, 2009 | LG DLE2512W Electric Dryer
Trying to wire a 3 wire dryer from panel box to dryer plug
Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
Oct 22, 2008 | Dryers
Trying to install 3 way cord with a 4 way replacement cord. I have disconnected all wires and put them back. My question is concerning the white wire.The wires that are already connected to the dryer red,...
In a three wire system you have 2 hot wires (black and red) and a neutral (white). the ground is connected to the neutral at the dryer. In a 4 wire system you have the 2 hot wires, neutral, and a ground. (green). The ground is connected with the neutral at the circuit panel. The hot wires at the dryer should be on the outside scres, the neutral should be in the center and the ground should be under the green screw. *****. .
Sep 23, 2008 | Dryers
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
220v dryer
If this is for the standard USA electrical distribution, the power cord connections to the terminal in the back of the dryer are as follows:
3-PRONG:
RED (HOT) - to the RED wire at the terminal
BLACK (HOT) - to the BLACK wire at the terminal
WHITE (NEUTRAL) - to the WHITE wire at the terminal (this is the center lug on the terminal).
NOTE: Some dryer cords may not be color coded. Just ensure the the center wire goes to the center terminal (neutral) of the terminal board. The other two wires are HOT and it does not matter how they connect as long as they go to the two outer lugs on either side of the Neutral.
4-PRONG:
GREEN (GROUND) - to the equipment chassis. (this is usually a separate lug that grounds this wire to the equipment cabinet or frame.)
I hope this helps you. Please post back if you have any further questions.
Apr 08, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
