Question about iPhone Apps
IPhone how do I remove a country on world clock?
How to delete international clock
      To see times in other cities, scroll up or down. To remove a city from the list, tap Edit, and then tap the red circle with the white horizontal line in it to the left of the city you want to drop. Then tap Delete. You can also rearrange the order of the cities displaying the time.
      How to Use the World Clock on Your iPhone - For Dummies
      www.dummies.com/.../how-to-use-the-world-clock-on-your-iphone0.html
    Feedback
    How to use the World Clock Android app - Time and Date
    www.timeanddate.com > Apps > Android Apps
    Time and DateTo find a city/location without adding it to your Favorites: Tap on the "Cities" tab located at the top of the screen. Scroll down to the city of your choice and tap on the city row to see details about it.
    How to remove or turn off world clock? ' Verizon Wireless Community
    https://community.verizonwireless.com/thread/807403
Feb 09, 2016 | Cell Phones
Delete international clock from galaxy 4
About 1,620,000 results (0.50 seconds) Search Results
    Samsung Galaxy S4: How to Create And Delete Clocks in ...
    www.itjungles.com/samsung-galaxy-s4-how-to-create-and-delete-clocks-...
    Due to business trips and different time zones/ working hours, you may sometimes need to use World clock to check your partners time zones to send emails and ...
    World clock constantly appearing when making calls - Android ...
    forums.androidcentral.com > ... > Verizon Galaxy Note 2
    Jun 28, 2013 - Recently, when making a call, the world clock appears and requires a bunch of clicks to close. ..... I have a Samsung Galaxy S4 with Verizon. LG G3 - world clock widget that will show two time zones ...
    Aug 9, 2014
    How to remove alarms from the clock?
    Dec 6, 2013
    Samsung Galaxy S4 Android 4.3 Update Issues - Page 3
    Oct 28, 2013
    How to remove clock and weather off lock screen?
    Oct 26, 2013
    More results from forums.androidcentral.com
Feb 09, 2016 | Eforcity FM Transmitter Car Charger...
How can i change the world clock.
About The World Clock - Time and Date
www.timeanddate.com > Time Zones > World Clock
Time and DateMark DST: Choose whether to display DST information for cities observing Daylight Saving Time. You can choose to mark cities currently observing DST with an asterisk (*) or with text (DST). Columns: Change the number of columns on the World Clockpage. You can have up to 8 columns.
How to Use the World Clock-Time Zones App - Time and Date
www.timeanddate.com > Apps > iOS apps
Time and Datetimeanddate.com explains how to use our World Clock-Time Zones application on the Apple iPhone.
Dec 28, 2015 | Cell Phones
Country lock
You can remove the country lock from your iphone using Remote unlocking method.Which is the safe and secure method to unlock iphone.You can get this service from SimpleUnlocking.com here you need to specify your country,Network name to which it is locked,IMEI number of your iphone.Here they unlock your iphone using latest versions of iTunes.
Sep 02, 2013 | Apple iPhone Cell Phones
Iphone country code open
You can remove the country lock from your iphone using Remote unlocking method.Which is the safe and secure method to unlock iphone.You can get this service from Unlock-Zone.com here you need to specify your country,Network name to which it is locked,IMEI number of your iphone.Here they unlock your iphone using latest versions of iTunes.
Aug 12, 2013 | Apple Cell Phones
Storm8 World War is stuck on small screen help
Massively Multiplayer ONLINE War Game! Join over 2.8 million players!It's the year 2020. A nuclear war has broken out. Most countries in the world have fought and many have been vanquished. 5 countries have emerged as the major superpowers in the devastating war. Which one will you be?
Start as a general defending your base from the enemy and fight to become the dominant military presence in the world as you march your way to victory in World War.
Jul 28, 2012 | Storm8 World Warâ„¢
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
World Cloack
As far as I can ascertain, you need to set your clock time to GMT, and then use the world clock feature to look up times in various cities. It would only be of any use if you were travelling.
May 18, 2008 | LG Prada KE850 Cellular Phone
Apple iphone
hi go to tweaks 1.1.2 folder and install iworld select country your in should be fine after that
Feb 11, 2008 | Apple iPhone Smartphone
iPhone Apps Logo
119 people viewed this question
Top Apps Experts
Lesley Cameron
Lesley Cameron
ray gallant
Are you an App Expert? Answer questions, earn points and help others
