Question about Steamist TC-135 Digital Temp 3/4" - 135-05.75 - Brushed Nickel
No power to control panel
Everything else is getting power, but no power to the control panel in shower.
How do i fix leak at connection from water to power shower ,should i seal it with silacon or get new connector
Don't try silicone, Use a new gasket or a new connector. The pressure will press out everything else.
Feb 05, 2015 | Home
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
Mira thermostatic shower water dripping from bottom of casing
Switch off the power supply to the shower at the consumer unit, it will probably have its own individual circuit breaker as it is such a heavy user of power. Try now to switch the shower, it should be dead and that is good. Remove the control knobs and remove the front of the shower unit. Check the electrics with an electrical screw driver to make sure that there is nothing that will cause electrocution. Trace the source of the leak, the most likely place is the compression joint to the mains water pipe. Tighten the compression nut until the dripping stops. Dry everything off with a paper towel and check there is no sign of further leaking. Reassemble the front with the knobs and switch the power back on.
May 27, 2010 | Home
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Mar 26, 2009 | Home
Im installing a shower panel in my shower
You must have gfci protection since the power is going to the shower and you don't want anyone to get electrocuted. You can either use a gfci breaker or you can install a regular gfci outlet between the panel and the shower. The outlet will be a cheaper solution to the issue.
please mark this answer as a fixya!
Mar 08, 2009 | Dreamline SHCM-2358-00 Aluminum Five...
Electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Dec 06, 2008 | Home
Steamist TC-135 Digital Temp 3/4" - 135-05.75 - Brushed Nickel Logo
46 people viewed this question
Top Steamist Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Steamist Hardware and Accessory Expert? Answer questions, earn points and help others
