Question about HP Photosmart Premium C309g multifunction InkJet Printer
Hp309g printer cartridge stuck on right side
Printer cartridge will not move from under housing on right side. I checked for paper jam and found none. nOw getting printer head errors but can't remove because it wont go to the middle of the carriage
SOURCE: carriage jam
i have the same problem i have a carriage jam problem please tell me how to fix it i have a mesage clear carriage jam and then press ok.
Posted on Jan 21, 2008
dg9dotorg
  • 151 Answers
SOURCE: paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Posted on Mar 10, 2008
SOURCE: I have an HP Officejet
hi, it could be that there is to much friction on the slider rod, this is the rod that the carriage slides on when printing it can get dirty and dry. try cleaning it with a lint free cloth and alcohol. then apply a couple drops of a light oil to the rod and spread it on all sides with your fingers. use something like sewing machine oil, dont use wd40.
You may also try this solution on this link first http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&cc=us&dlc=&product=391194
if that doesn't work then that means that the carriage motor on your printer have gone bad. There are motor parts being sold on the net that you may want to check out first but if that sound inconvenient to you then there is most likely a mechanical issue causing the error with would require the printer be sent to hp for repair. this probably wont be worth the time and money. so be prepared to possibly buy a new printer.
Posted on Jul 07, 2008
pagebor
  • 2785 Answers
SOURCE: photosmart printer. paper jammed, removed it. now cartridges wont move
your printer needs servicing
Posted on Jul 21, 2008
SOURCE: Carriage jam
There's a small locking mechanism that holds the carriage in it's home position. This needs to be slightly sprayed with WD-40 or a similar lubrication (small amount). Problem solved.
Posted on Dec 30, 2008
P4350
The carrier slides back and forth on a bar that must slide smoothly. When you open the printer up, the heads come to the center for cartridge removal, so that part of the bar is oiled. Try lightly spraying a silicone or Teflon spray or a drop of high quality machine oil to the bar where the head will go through it, smearing it along the the bar. Another part is the plastic belt with teeth on it that moves the head from side to side. If the teeth have broken off, the head won't move properly. Some of these printers have an entire head assembly where the cartridges set that can be removed after the cartridges are out. If this print head assembly is damaged or worn out you will also get the error. The head damage is usually because some one yanked jammed paper vigorously out, pushing the head out of position, or the print head was moving when something stopped the head.
Aug 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
May 24, 2011 | HP PSC 2355 All-In-One InkJet Printer
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
I keep getting error message C000 which tells me to shut down the printer and restart it. How do I fix this. Thanks
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Jan 29, 2011 | Canon Office Equipment & Supplies
Error code C000
Follow these steps :
1) Make sure the tank holding all the ink cartridges is properly aligned and can move side-to-side.
Nov 13, 2010 | Office Equipment & Supplies
Error C000!! what can i do it wont print,
  • Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
  • If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
  • Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Sep 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I am receiving a printer error C000 what does mean? I've tried everything... help!
Suggestions from my recent encounter with this error:
when inserting cartridges tilt them forward and down so they go under the plastic lip then seat the rear so that the light comes on.
Please rate my help++++Thanks for using FIXYA
Dec 01, 2009 | Canon PIXMA MP620 All-In-One InkJet...
HP Photosmart Premium C309g multifunction InkJet Printer Logo
422 people viewed this question
Seeker5211
Seeker5211
