Question about Dell 1710 Laser Printer
Paper goes half way through and then stops and registers paper jam!
Dell 1710 laser
Http://www.fastprinters.com/ProductDetails.asp?product_id=LEX-56P1826
Exit sensor is broken , look for the same part for a Lexmark E330 if the URL dies.
Posted on Mar 26, 2009
The paper jams half way through
I would remove the paper tray, inspect the area carefully and look for debris in the area, i.e. paper clip, staple, rolled up paper etc. Then do the same thing for the area where the paper exits. If you are able to turn the rollers by hand, the offending item may expose itself.
Jan 20, 2015 | Dell 1710 Laser Printer
Paper jam light is on
Look real close. It is difficult to see very small pieces of paper that coudl be lodged in many areas. Also if you take a clean cloth with a little rubbing alchol and clean the sensors, this may help
Jun 17, 2010 | Dell 1710 Laser Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Hi i have a problem during printing is the paper is strucking in the middle of during printing processes the printer modle number is Dell 1710
Hi, the printer manual or the printer itself would have instructions on how to remove paper jams. Also loosen the guides alongside the paper feed a bit to ensure it is not holding onto the paper sides too tightly as this will continue to cause jams.
Nov 29, 2009 | Dell 1710 Laser Printer
My dell 1710 has a paper jam, but I cannot see it. How do I find it?
http://www.ehow.com/how_4929022_fix-paper-jams-dell.html
Oct 12, 2009 | Dell 1710 Laser Printer
Dell Laserjet 1710 - won't take the paper from the tray
clean the paper pick up roller and check any paper pieces is there
Oct 05, 2009 | Dell 1710 Laser Printer
Dell 1710 paper jam
Next time don't buy Dell. That's the solution.
Oct 05, 2008 | Dell 1710n Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
1710 Printer
The problem in my case was not fixable, the small switch sensor inside the printer had broken free, the engineer's informed me that it would cost far more to fix the problem than it would to buy a new printer.
Anyone want 2 boxed toner cartridges for a Dell 1710 printer?
Aug 07, 2008 | Dell 1710 Laser Printer
Paper jam in a Dell 1710
This is a terrible terrible printer. Aside from taking the printer apart it seems like your only option is to pick the paper out bit by bit with needle nose pliers.
Dec 12, 2007 | Dell 1710 Laser Printer
Dell 1710 Laser Printer Logo
605 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
