Question about Dream Maker Spas Pool & Spa
Need help trouble shooting heater problem
I get a s/n code [over temp heater code ? ]need to know what to replace or repair
    Scholar:
  • 111 Answers
Yes this is your Hi Limit (High Temperature) sensor.
This is a safety device so replace it.
On most DreamMaker spas the Temperature Hi Limit sensors share the same 4-Wire plug, you will have to replace both.
If your sensors have a telephone style plug you can replace the Hi Limit with out replacing the Temp sensor.
Posted on Feb 20, 2012
3 line error code hot tub wont function how do i trouble shoot
check to see if recirculation pump is working if ok check pressure switch if ok check heater element and temp sensor
Jun 22, 2016 | Jacuzzi Premium Spas - Spa Cover -...
2013 BMW X5 replaced the spark plugs coils still have the p0301 p0306 codes
Trouble shooting a misfire, Code P0300, P0301 ... - YouTube
? 23:39
https://www.youtube.com/watch?v=G_grIaTgdRI
Oct 26, 2013 - Uploaded by Robert DIY
Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, ... How to Diagnose Codes P0301 - P0310 - Cylinder Misfires ...
Diagnose and Repair Misfire Diagnostic Codes P0301 ...
? 9:22
https://www.youtube.com/watch?v=yK7v11ASVgI
May 6, 2014 - Uploaded by JamieJones TheCarMan
Diagnose and Repair Misfire Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A Hyundai ..... P0303 Honda cylinder 3 misfire detected code - Change spark plug - ELM327 OBDII reader with Torque - Duration: ...
? 15:59
https://www.youtube.com/watch?v=Sg7iFytxfzQ
Feb 16, 2014 - Uploaded by Robert DIY
Misfire Trouble Shooting: 30 to 60 minutes ($50 / $75 / $120) If your car is ... Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A ...
Dec 08, 2015 | BMW 2013 X5 xDrive35i
I started the test cycle to make sure it works properly and in the middle of the test a code of D80 appears and a little smoke witch is not good. Does anyone know what this code means?
Digital control washers and dryers usually have a list of common trouble codes listed in the owners manual under, "trouble codes". Unfortunately, mostly simple codes are listed. My guess would be to check the thermister, & thermal protection fuse but you can get model specific advice in the trouble shooting section at repairclinic.com. Good luck. Try this link: http://www.repairclinic.com/RepairHelp/Appliance-Repair-Help-Lawn-Mower-Repair-Help-Small-Engine-Repair-Help
Sep 04, 2015 | Dryers
How to trouble-shoot a heating problem on a cal spas "supra" above ground tub ?
what' s the problem? is the spa running but the temp doesn' t go up. is it set on vacation mode? can't help without knowing exactly what the issue is.
Sep 27, 2014 | Pool & Spa
Pool heater
hi please try to reset the circuit board, by turning the heater on/off from electric power, if don't work you got to replace the water temp sensor located inside the circuit board (BROWN WIRES) if still display the same problem try new circuit board.for this type the heater a master temp, pcb will work rev.R-13 Good luck. if you need part # let me know, remenber before replace any electronic parts in heater SHUTT THE POWER OFF.
May 04, 2013 | Pool & Spa
A/t oil temp code 79. how do you trouble shoot.
if you do not know how to fix it, i think you should take it to professional car repair shop.
_____________
digimaster 3 update instruction
Apr 02, 2013 | 2001 Subaru Forester
How to repair a Raypack pool heater that displays a ROL fault code?
simply replacing the roll out fuse wont solve your problem. those safeties open from an over temp situation or negative pressure down draft. clean out any dirt and debri from venting, inspect the underside of heat exchanger for build up or soot. ensure you have proper combustion/ventilation air openings if heater is in a shed. if heater is outdoors, Raypack is notorious for getting downdrafts back down the draft hood causing burner flames to come outside the burner box
May 20, 2012 | Raypak Rp2100 Pr406aen 406k Natural Gas...
I need to know which O2 sensor heater to change out?the error code was PO141, i dont know what side it is tho?
SHOULD SAY EITHER UP STEAM OR DOWN STREAM ON THE COMPUTER. UP STRAM IS RIGHT SIDE AND DOWN IS LEFT SIDE
Aug 03, 2011 | Honda Accord Cars & Trucks
I have a Pentair minimax 250k electronic. Opened pool today and when I turned power on to the heater, it won't get through startup sequence. Dashed lines flash, then 888 and service light comes on. ...
Most of the time I have found the problem to be the thermistor. It is located on the water manifold of the heater. Usually the panel lights, flashes then to 888 and back to dashed lines. SW light is green, and service light is red. It costs 25 to 45 dollars, and takes 5 minutes to repair. New thermistor looks identical to old so replacing it is very easy.
thanks please let me know if this was helpful
May 21, 2011 | Pentair Minimax NT Heater
What is diagnostic procedures for DTC p0135 & p0141
Oxygen Sensor problems... P0135 (Bank 1, Sensor 1) and P0141 (Bank 1, Sensor 2)
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it.
The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Symptoms: You will likely notice poor fuel economy the illumination of the MIL.
Causes: A code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
Possible Solutions:
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141.
Symptoms: You will likely notice poor fuel economy the illumination of the Check Engine Light.
Causes: A code P0141 may mean that one or more of the following has happened:
O2 heater element resistance is high
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
Hope this helps (remember to rate this answer)..
May 11, 2011 | 2000 Nissan Maxima
Pool & Spa Logo
529 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
