Question about Crosley CW5000 Front Load Washer
How do you replace the motor pulley on a crosley cw5500w washer
2 Suggested Answers
vostendorp
  • 347 Answers
SOURCE: I have a crosley cw5500w top load washer, it is
Yes their are inlet filter screens where the fill hoses hook up to the washer if you shut off the water at the wall and remove the hoses at the unit and look and you will see them carefully pop them out and clean,,,And you will be back in operation
Posted on Sep 16, 2010
I need to know where the idler pulleys go on the motor
Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part ...
? 13:58
www.youtube.com/watch?v=WX0KjiQJWpY
Apr 7, 2011 - Uploaded by PartSelect Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part# 6-3700340) ... Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, ...
Sep 15, 2015 | Dryers
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Crosely CW5500W washing machine. I need R & R instructions for the transmission. Do's & Don'ts etc. I do alot of automotive work and understand both ends of a wrench. Can you help? I have...
Good day Mr.Wesley Smith...
I have instruction guide on how to replace transmission and safety precaution when you do that..But unfortunately that files is have a larger size that can't send it to this tread..So I need your yahoomail address to send attachment..This attachments files compose of picture so you can easily follow the instruction given..Please reply to this tread with your yahoomail add..
I will wait for your immediate response...Please reply only with this tread with your email address..
Thank you
Nov 19, 2011 | Crosley CAWC529JQ Top Load Washer
I have a crosley cw5500w top load washer, it is filling very slowly despite adequate water pressure. Is there an inline filter that could be clogged?
Sep 16, 2010 | Crosley CW5000 Front Load Washer
Replacing drive belt on Cosley Washing Machine
You must get it off with out damaging the pulley or motor, You may have to cut it off with a hack saw. Don't beat on it or you might ruin the motor.
May 08, 2010 | Crosley CAWC529JQ Top Load Washer
Washer fills up then stops like its unpluged
the waterpump belt or belt pulley spring is broke or waterpump may be defective. common prob is belt pulley spring is broken.
Jan 08, 2010 | Crosley CAWC529JQ Top Load Washer
My washer will not spin. For about a year a belt
Move the machine from the wall and open the back panel. Usually there is an area where you can see the motor, pulleys and belts. If the belt is broken you can see it sitting there, inside the machine. All you have to do is guess which pulley it came from. Usually the pulley groves are shiny if the belt was from those. You may have to slacken the bolts holding the mechanism to replace a new belt, that's if you find another belt from the manufacturer. Or, alternatively you can purchase a similar belt from a tool store. It is difficult to say further because I don't know how old the machine is, but all machines have the same belt and pulleys operations.
Sep 22, 2009 | Crosley Washing Machines
Washer wont agitate.
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 05, 2009 | Washing Machines
Machine won't agitate or spin
Dear customer,
 We recommend u to do the following when the washer doesnt spin or agitate,
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the timer control
  11. Test the centrifugal switch
  12. Test the water level switch
for more details about self testing plz try the link  http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 08, 2009 | Crosley Washing Machines
Crosley CW5000 Front Load Washer Logo
59 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
