Question about Toro Garden
How do i adjust the self propel on a toro sr4 model 20062
  • 77 Answers
SOURCE: my toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Posted on Aug 09, 2009
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
#1 Taper
  • 1040 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: Honda Harmony self propelled not propelling. Belt
Do you know for sure that the belt is not stretched. Make sure also that it is on the pulley correctly and the pulley is spinning with the shaft you also might have spun a key.
Posted on Oct 09, 2009
Need to know where to look on my mower to find out what info I need to find a new belt for my Toro SR4 Super Recycler.
I believe you will need belt Toro part # 91-2258 Try Partstree.com or call 1-877-798-7278 they are great to work with and can guide you to id your mower and get you the right part.
Jul 05, 2012 | Toro Power Lawn Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
Toro self propelled model 20066 loud noise once engaged
They will honor it - go now - - quickly and simply explain things - Toro is a good stand up company.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
6.5 toro walk behind self propell b&s engine. self propel does not work
Try adjusting your self propel cable. A slight extension of the cable (1/4 inch) will double speed, so do a little at a time. Take the back guard off and clean debris 2 or 3 screws and it is just a cover so nothing will pop out unless that is your real problem. You should have grease fittings behind rear wheels so squirt 2 times with grease gun in each wheel and 1 squirt every 3rd mow.
Aug 05, 2009 | Toro Lawn Mower With Toro Power Tools
I have a TORO 6.5HP Mower Model #20017 Self Propel Drive-
check cable.check belt and check gearbox.one of these will be bad.if not all
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
198 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
