Question about Sewing Machines
How can I tell which cams fit the elna carina. I understand there are some which are screw in instead of snap in made for older machines? Can you tell the difference visually?
  • Sewing Machines Master
  • 7,365 Answers
Check with sewvacdoctor.com
Posted on Feb 08, 2012
SOURCE: machine doesnt switch off keeps running slowly
Thanks for return email.
I took the machine to an Elna dealer who fixed the problem by by-passing the (small board) switch that returns the needle to the ready position after filling the bobbin. It is quite frustrating not having that facility after being so used to it.
Kind regards
Yolande
Posted on Apr 20, 2010
Tally Girl
  • 1129 Answers
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
Posted on Mar 27, 2011
Tally Girl
  • 1129 Answers
SOURCE: How do you thread the Elna Carina?
thought I had a manual with an image of this but can't find it.
But pretty simple.
tally_girl_31.jpg Place thread onto one of the spool pins at the back right, and pull thread across to the left and around the white blob on top of the machine head then back to the right to the little thread eyelet, down through this and down to the thread guide taking thread around it from the right and back up on the left side, back up and through the thread take up lever, then down again catching behidn the little thread guide, then to needle bar thread guide, then to needle eye.
ALWAYS HOLD THE two threads firmly behind the pressure foot when you start sewing - Really important.
Always wind and insert the bobbin with the holes on top, smooth side downwards. Place bobbin into bobbin holder and take thread take towards you and into the tension spring groove, pressing down on the thread with your finger until you hear it click into the tension spring. pull back the other way to check it is in there, if it comes out, do it again.
Bobbin will rotate anticlockwise when you pull the thread.
THen put needle plate cover down and draw bottom thread to the top using flywheel or the needle up/down button on these lovely machines.
Hope this helps, if not post again and I'll dig out images from my SU manual.
Posted on Jun 08, 2011
Tally Girl
  • 1129 Answers
SOURCE: Elna Carina service
Search yellow pages for local sewing machine repair men, then ring them and ask if they can replace the capacitors on your machine. If they start talking knowledgably about the Carina then I'd take it to them. In user groups, these types of technicians are called OSMG (old sewing machine guy) and they are worth their salt. There is also White Sewing Center in USA. website www.whitesewingcenter.com, and they specialise in Swiss Elnas.
Posted on Jun 16, 2011
Tally Girl
  • 1129 Answers
SOURCE: Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
Posted on Jul 13, 2011
Needle plate cover for elna carina sewing machine
An Elna dealer is probably a good place to check. Also check with sewing machine parts vendors online. Since your machine is older, spare parts may be difficult to find unless you are lucky enough to find something on eBay, etc.
Nov 27, 2016 | Elna Sewing Machines
How to remove a can from a elna Carina electronic 65
you need to set the stitch width dial to zero, the stitch length dial to zero so that the cam following arm is disengaged and moved back off the cam. Now look at the cam, it is sitting on a silver shiny spindle, press down onto this with your fingers and this will unlock the little finger which locks onto the cam, releasing the cam upwards. Press firmly and it should release.
Jul 03, 2015 | Elna Sewing Machines
ELNA CARINA FOOD PEDAL NOT WORKING
Elna Carina has an air electronic foot controller, so you need to firstly check the air line coming from the round air pedal has no holes, is not crimped or squashed under the chair leg. Hold the plug end against your hand or cheek, squeeze the round bulb and see if you can feel a puff of air coming from it. If no, then check the air control black membrane for a hole, ditto the air line hose. You can still buy parts from sewingpartsonline.com for these Elna Carina Electronic 66 Parts . If the line and foot pedal are sound, then the problem lies on the internal actuator which is inside the right side panel of the machine. You can remove this panel by undoing two screws on the side (disconnect from power first!)
The panel will remain connected to the machine body by some cables, you may be able to check out the actuator and see if it is faulty. If its just a tiny hole in it, it might be repairable with a drop of superglue. For parts/service in the USA, Whites Sewing Center is the Swiss Elna specialist, and they may have spare parts in stock.
Feb 09, 2015 | Elna Sewing Machines
Elna carina 390 b power cord/foot pedal
check with a elna dealer
sew4less.com
sewingmachineplus.com
ebay
May 28, 2012 | Elna Sewing Machines
Elna carina manual
You may find this at www.diplodocs.com or www.scribed.com free, otherwise you will probably need to buy it from www.sewingpartsonline.com or www.sewing-machine-manuals.com , I think it came as 2 books, Instruction Manual and Sewing Guide.
Mar 23, 2012 | Elna Sewing Machines
Does anyone know of a cam to use in an Elna Carina that makes a stitch very similar to french entredeux? What is the cam number?
I am certain that we demonstrated this stitch with voile or hankerchief linen and using a wing needle and fine silk thread or rayon machine embroidery thread with the turkish hemstitch cam, cam number 140.
For the non heirloom sewers out there entredeaux looks like this.
Here is disc 140in the Elna discs sampler flyer
I am a member of the yahoo newsgroup called "Elna Heirlooms" and the following image was contributed by a member. I believe that members also list any Elna items they may wish to sell.
Or you could contact White sewing centre to order this cam if you don't already have it.
If you find these images are just too small, feel free to email me on cwrogers@tpg.com.au and I'll send you the jpgs.
Jul 13, 2011 | Elna 2005 Mechanical Sewing Machine
Elna Carina service
I just had the same question for servicing of my Elna Carina. I contacted customer support for Elna and received the following e-mail: "Elna machines can be serviced by most authorized Elna dealers. If you need to locate an authorized Elna dealer in your area, please visit our official website at: www.elnausa.com and click on “Dealer Locator” on the top right hand side of the page."
Nov 06, 2008 | Elna 2007 Mechanical Sewing Machine
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
