Question about Dryers
Maytag dryer heating element won't come on
Checked thermal fuse. good. checked High Limit thermostat. good. replaced heating element. New heating element does not light up. what could cause this.
  • 1 more comment
  • Dominic Zito Feb 07, 2012
    The element had 126 volts at both connections. Should it be 110 or 220volts?
  • danny Hendrickson Feb 11, 2012
    keep back tracking up past the last component with the purple wire on it,this with the multiple wires on it is the (Cycling Thermostat) just check the 2 large wires as the 2 smaller ones are the sensor wires ,keep back tracking to the timer,the other leg of 126 volts has to be here(try bypassing this cycling T-Stat's larger wires.(leave the one meter lead on the black wire that showed 126volts and back track the other red lead till you find appx. 126volts and then you show a combined nominal 240 volts
  • Dominic Zito Feb 15, 2012
    OK, so I finally looked into the control panel. Problem was obvious, since one of the leads from the temperature control switch was fried off. put on a new connector, hooked it back up and everything works great now. As it turns out the old heating element was actually still good but since I had already paid for and installed the new one, I just left it in. Now I have a spare in case the other element ever goes out. Thanks for all your help and input into helping me fix this problem.
    President:
  • 2,468 Answers
You should have a nominal 240 volts between the 2 heating element connections
Posted on Feb 08, 2012
  • 3 more comments
  • Dominic Zito Feb 08, 2012
    I cant get a reading between the two heating element connections. When I put the positive lead from my meter on either connection and the neg to ground I get 125v. When I put the pos on one side and the neg on the other it doesn't read anything. I did check the outlet and I get 245v when I put the meter on both hot legs. I cannot get the heating element to read 245 though.
    remove and isolate the heating element and just check the terminals during operation,also what make/model # is this dryer?,is there possibly a center neutral connection on the element thats burned off also make sure the meter is set to read A.C. voltage not D.C. voltage
  • Dominic Zito Feb 11, 2012
    Maytag MDE 6400WYW Atlantis series. removed the heating element and checked just the leads. The black wire coming from the motor had 126 v. the purple wire had zero volts. the purple wire comes from what I think is the overload protector. It has like 5 or 6 wires leading to it. Definitely have the right setting on the meter, AC volts. I tried putting one lead from the meter to the black wire and the other to the purple wire but got nothing. Black wire to ground gets 125v. Purple wire to ground gets zero volts. Thanks for your help. Hopefully we can figure this out soon. tired of hanging clothes up to dry! LOL
    * MDE 6044 AYW NOT WYW
    WOW! sorry. having a tough time typing today. MAYTAG model # MDE6400 AYW
shinn8
  • 85 Answers
SOURCE: my kenmore 70 series dryer
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
Posted on May 27, 2009
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
huuum
  • 750 Answers
SOURCE: Maytag Neptune dryer overheating
Hello
Welcome to Fixya
My name is Huum,
Yes, I agree it is the high limit thermostat, or the motor is bad!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
milten1
  • 1304 Answers
SOURCE: Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Posted on Oct 21, 2009
Testimonial: "Thanks, I'll replace everything! "
SOURCE: Thermal cut-off blows and high limit thermostat is
in this case we put the lower temp thermostat in the oven at 170 degrees till it was hot and measured with ohm meter and it was open. After it cooled down some it went back to being a short. Now with this part in the dryer and the new high temp thermostat
and it blew shortly after being turned on. A possiblity is that there is a short by passing the 150 degree thermostat and the element keeps being on and causes the 350 degree thermostate to blow.
Posted on Apr 07, 2010
Why is my maytag electric dryer not heating, I checked the high limit fuse for continuity, it's fine, I pulled the heating element and saw no breaks it also checked good on continuity
Several things can cause this. Improper voltage, inadequate venting, thermostats, fuses, burnt wiring, heating element, timer, or motor. Someone will have to troubleshoot all that v
Nov 18, 2017 | Maytag Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Amana dryer not heating, replaced Thermal Cut off, High limit thermostat and Thermal Fuse, and new breakers in fuse panel
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
Dec 02, 2011 | Amana NED4500VQ Dryer
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
No heat (replaced heating element and another
It sounds like you replaced the heating element and the small thing you refer to was most likely the thermal fuse. If these are the components that you replaced, and if they are indeed good, the next thing to look at if the dryer is not heating up is the high limit thermostat. It is most likely faulty if the element and thermal fuse are good. Hope this helped and best wishes. Here is a picture of a thermal fuse and high limit thermostat to help you figure out what is what.
Jul 30, 2009 | Dryers
Dryers Logo
280 people viewed this question
Top Dryers Experts
