Question about GE Refrigerators
Ge refrigerator GSl22jftabs not making ice, and not cooling
GE side by side GSL22jftabs stop cooling on freezer and refrigerator side. Icemaker stop working prior to this and the freezer side will not defrost.
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Posted on Nov 04, 2009
  • 2699 Answers
SOURCE: GE Profile PSS26PSTB refrigerator ice melts inside icemaker
when you open the freezer door do you hear the fan blowing,you could have a bad evap fan motor,also if there's ice on the back wall you have a defrost problem,take off the inside back wall of the freezer where the ice is,you need to shut the control off and melt out all the ice,g.e. has had alot of problems with their computer boards which is a very expensive part number WR49X10152 around 200 bucks,look behind the kick plate on the bottom of the fridge and hopefully the tech sheet will be there,it will tell you how to put the machine into defrost,do this first before you melt anything out or before you touch the control,i think you click the lite switches together 5 times to make it go into defrost,it should tell you on the tech sheet,if ithe heater doesn't come on you need to read out the heater with a meter to see if it's good also read out the defrost thermostat,you have to check the thermostat while it's cold if the t-stat warms up you won't be able to check it, you should change out the t-stat anyway so you can cut the wires going to the t-stat,bypass it by connecting the wire directly to the heater and click the lite switches 5 times and the heater should come on,if it does leave the heater on to help you melt it out.so if the fan is running on the freezer side,click the lite switches 5 times and the fan should shut off and then you'll know it's in defrost,the heater should come on ,if the heater and t-stat read good and it won't go into defrost then it 's the board,also you can take out the board in the back of fridge ,unplug it first and look at the board for burn marks on the back or on the soldered spots,the board tells it when to go into defrost and melt the ice off the coil and like i said g.e.has had a lot of problems with the board,if you need any more help let me know,good luck
Posted on Mar 24, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
Ge profile side by side model pye22kskbss is not making ice.
Is the icemaker getting water into tray? If not>refill valve is ng
Is there ice in the tray? If so, heater element is ng and that needs replacement.
Or just get a new icemaker on the cheap at site. eBayeBay
Sep 09, 2017 | GE Refrigerators
GE GSL22JFTABS Frost buildup on back wall of freezer and ice maker not making ice
Your unit is not defrosting, causing the unit to build up ice and not allow the air to flow. There are 3 possibilities, listed with the most likely first.
1. The DEFROST HEATER in the freezer section, just behind the cover along the back wall of the freezer.
2.The DEFROST BI-METAL which is just about the HEATER, it is a small round thermostat that keeps the HEATER from getting too hot
3. If both of those parts are good, then you have a bad MAIN BOARD. The board regulates the defrost cycle, which replaced the older defrost timers.
May 20, 2012 | GE Refrigerators
GSl22JFTABS freezer not getting cold Fridgerator cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | GE GSS25LGM Side by Side Refrigerator
GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 30, 2010 | GE Monogram ZDI15C Automatic Icemaker
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Freezer stopped making ice cubes
If temps are ok, then be sure you ice ben is in properly. if that checks ok, check for water/ice in ice maker mold....Try turning unit off and then on in 5mins. this resets the ice maker...if that doesnt work, need to check for power at icemaker. good power means bad icemaker. no power means bad board.(usually) Would suggest you to have a cert GE Sercvice company look at it if no power to ice maker.
Jun 09, 2009 | GE GSH25JFR Side by Side Refrigerator
Icemaker won't stop making ice
for safty call the store because of the warranty
Mar 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
