Question about Sony 8mm Stantard Grade 120 Minute Camcorder Tape P-6120MPL USA 8mm Tape
SONY MP 120 8mm video cassette
My tape played back fine the last few times I watched it through the camcorder, but now when I try to view it, I get static/white lines running across the screen and the audio fades in and out. The first few times this happened, I fast forwarded the tape a bit and that seemed to solve the problem, but that didn't work the last time. I've cleaned the rollers on the recorder and it still fades in and out. I'm devistated because it is the tape that the birth of my son was on and us bringing him home.
I have tried other tapes of the same recorder and some work fine, some do the same thing.
The tapes have been stored in a climate controlled environment in their cases, inside a box with a lid. They have been kept away from dust and too much handeling. I'm hoping that the recorder is just old. I haven't tried viewing the tape on another HiFi 8mm camcorder.
Thank you for your time and I hope you can tell me what may be going on.
Have a great day and God bless you all.
Ian's Mommy
  • IansMommy Oct 22, 2008
    Thanks for your quick response!
    I really appreciate that and I'll try your suggestion.
  • ginablank Dec 26, 2008
    I am experiencing the same difficulties. I am trying to view 8mm video cassettes in my Handycam Camcorder, and I get choppy video or video with static lines, and very minimal audio. My hard copy cassettes, too, have been stored safely in cases and in boxes. Cleaning the heads inside the camcorder with rubbing alcohol didn't work, and neither did ffwd or rwd.
    I am glad to hear that it is probably just really dirty camcorder heads (the camcorder IS 16 years old, after all); where were you able to find a cassette head cleaner?
I have the same issue but noticed that I only have this issue with Sony 8mm tapes (and I convert a lot of tapes for customers). I play them in a Sony camcorder. It usually runs well for 30 minutes and then starts with the static issue. The only solution I found so far was to restart where the static started and go from there. I thought that maybe they are electrostatically charged,
Posted on May 13, 2010
  • 10,594 Answers
Problem is dirty / clogged video head of v-8 player or camcorder what ever you are using for playback. Use good quality video head cleaning cassette for head cleaning.
Please check tapes on another camcorder as tapes seems OK.
Posted on Oct 22, 2008
I'm getting lines and mosaics on the video tape output of my Sony DCR-HC40, and a message on the viewing screen to use a head cleaning cassette. After a minute or so the lines go away and the video is...
NEVER try and manually clean your heads in your camcorder. The drum assy and heads are much more fragile and easily damaged than that of a VCR. NEVER spray any type of liquid/chemicals in or on your camcorder. A Sony miniDV head cleaning cassette is what you need. There are other brands out there, but Sony is hands-down the best. When using a head cleaner, play it for only 5 to 10 seconds at a time and then try your tape again. If it has improved, but still has problems then play the head cleaner for another 5 to 10 seconds. Hope this has helped. www.austintelstarservices.com
Sep 01, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
I have a sony trv510. I took several videos many years ago. I tried to play them in my camcorder, but all I could see was a blue screen. I took the videos to a camera store and they said the videos were...
Try transferring the videos to your computer. Connect the camcorder to your computer and open windows movie maker. Then use the capture from camera to capture it from the camcorder. Once its done you can save the captured video to your computer and burn them to a DVD.
Hope this helps,
Sai.
Jan 22, 2010 | Video Cameras
C:32:23
This is a common problem with alot of Sony CamCorders...The solution is simple.....GIVE IT A WHACK!!!
Seriously, Take the battery off the device, Give the camera a smart "smack" on the tape side of the unit and power it back up.
works in 90% of cases!!!
Sep 22, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Sony 8mm Stantard Grade 120 Minute Camcorder Tape P-6120MPL USA 8mm Tape Logo
2,507 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
