Question about Razor Cycling
Mx400 electric dirt bike when charging wont charge light wont come on only when in the on postion it lights up
Lights on bike turn on when charge pluged in and switch is on when switch is off it should light up but it doesnt
  • 427 Answers
SOURCE: off-on switch as bright as when it was new. green
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Posted on Jul 14, 2010
  • 42 Answers
SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
Posted on Jan 08, 2009
  • 420 Answers
SOURCE: bike wont start..possible electrical
I am assuming you checked to make sure the battery is charged? When my ignitions switch went bad it showed signs of failure first I had to jiggle the key to get it to work. That being said it could be the switch, it is a very simple change and if you get an after market switch not that expensive. The Harley switch is $40.00 I got an after market for around $15.00.
Posted on Apr 09, 2009
  • 200 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
Clean and tighten all wires connected to the battery, motor , controller etc.being doubly sure of all grounding wires . Don't take any shortcuts ...remove wires ,clean and inspect for cracking or burning, clean and or replace....this will pay off for you...Good Luck....Tim
Posted on May 12, 2009
  • 832 Answers
SOURCE: electrical problem,possibly relay?
Check for busted fuse in the fusebox.
Posted on Sep 27, 2009
What could be the problem if my son dirt bike says its fully chaged but when he turns the throttle nothing happens
Did the socket the charger was plugged into actually have 120vac in the socket?
Or are you sure the charger is actually working? Is there a short so that the battery is draining as fast or faster than the charger is providing a charge?
Mar 27, 2015 | Razor Dirt Rocket MX350 Miniature Electric...
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
2000 acura tl battery light does not come on when ignition key turned to on postion battery not chargeing
its probly ur alternator. u can check it by starting your car then taking off positive cable when its running. if it stalls its the alternator not charging
Oct 09, 2012 | 2000 Acura TL
Hi, my son has an electric razor quad bike with two 6 volt batteries. We have just replaced both batteries and the full charge light shows when you switch it on but it still wont start up. Can you...
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
Mar 29, 2011 | Razor Dirt Quad Bike
Just got this little dirt bike from a yard sale. Trying to figure out charging the battery. When I put the charger into the outlet, the little green light comes on. Then when I connect black charger end...
the charger led should turn orange or red when charing then turn green when finished charging, but without knowing the model of the charger its had to say
Dec 12, 2010 | Peg Perego 12v Battery
2008 R6. Battery discharges completely when allowed to sit. Owner replace four batteries. Voltage checked with bike at 5000 RPM and is charging (14.4 V). When the bike is put on a Battery Tender, the...
You have a voltage drain on your bike while the key is off that is why the tender wont full charge the battery. If you have any electrical accessories such as an alarm try disconnecting them they may be draining your battery while sitting. If no accessories then you have a short somewhere in the harness causing the drain.
Nov 02, 2010 | 2008 Yamaha YZF-R6
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
I can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
Cycling Logo
88 people viewed this question
Top Razor Cycling Experts
Erick Williams
Erick Williams
Level 1 Expert
Donald Ayers-Marsh
Lawrence Oravetz
Are you a Razor Cycling Expert? Answer questions, earn points and help others
