Question about 5901 Security Remote Start System
What does the viper valet toggle switch look like?
2 Suggested Answers
  • 4 Answers
SOURCE: Viper
did it ever work before?
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
Posted on Mar 25, 2010
Where the **** is the Viper valet button?
Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
Feb 15, 2016 | Remote Start System
Reset remote for a Viper 300 alarm 2 button 2 way to start my ignition no valet switch
If you follow this diagram, you should be able to locate your Valet switch. I have seen other questions like this and I believe that they have hidden the function by using an exsisting switch, seldem used(?), in your console. All you should have to do is eith tract the wire that comes from the port on the alarm modules body, or apply +12vdc to one of the leads identified for the valet function.
Best of luck!
Viper 300 ESP Installation Manual Wiring Quick Reference Guide
Feb 12, 2016 | Viper Vehicle Parts & Accessories
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
HOW TO FIND THE VALET SWITCH IN A 2000 DODGE STRATUS
The valet button on the Viper 5701 is located on the antenna which is normally installed on the front windshield. Viper calls this button the "control button".
Here is a link to the owner's guide:
http://www.directeddealers.com/manuals/OG/Viper/G5202V%202011-03%20web2.pdf
Feb 20, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello my name is Matt. I have a 96 Chevy S10 and yesterday evening the alarm started going off. I first tried the remote, but that won't shut it off and I can't find a reset switch in the truck. Followed...
Go back to that blackbox and look for a blue two pin plug. Trace the gray and black wires from that plug to the black push button valet switch or, a silver toggle switch. Once you have located one or the other, turn the ignition on, press and release the valet switch. The older modelalarms came with a toggle switch, so if the toggle switch is present, just cycle it off then on with the ignition on. This should disarm the alarm. Have you started the vehicle lately? The alarmmay be triggering because the battery is dying.
Sep 22, 2010 | Viper Vehicle Parts & Accessories
Viper car battery went dead now alarm light on
you are in valet mode.
find valet switch under dash or driver kick panel.
turn key on
then push the valet switch for a few seconds.
light should go out and then function properly again.
Jan 16, 2010 | Vehicle Parts & Accessories
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I can't find a valet switch for my python 460hp?
you can find the "brain" by tracing the wire from the LED blinking light to the brain than look for a grey and black wire which is the valet switch. Don't look for a toggle switch either, your looking for a little black button not a silver toggle but a little black button. Depending what vehicle you have also matters, for instance if you have a GM truck look in the side dash fuse panel or look BEHIND the hood latch handle. It's a ***** to find sometime but essential that you know both where it is and what it does and how it works.
Aug 08, 2009 | 460HP Security System
5901 Security Remote Start System Logo
75 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Tre Elkins
Shehu Pro
Shehu Pro
Joseph Gallucci
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
