Question about Westinghouse Washing Machines
Westinghousewashing machine lt959s lid wont register as close
Lid sensor not workinh
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Machine wont start after lid is closed unless lid is bumped
Check your lid switch. The symptoms of having to move the washer lid is a symptom of a lid switch malfunction. Other symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop and compare.
If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing so I can provide you with better assistance. Please include your model number (located on a nameplate along the wash tub rim under the lid) if its different than the one you listed the question under so that I may be able to assist you better. I hope this information is helpful to you.
NOTE: You do not have to drain the wash tub to perform this repair.
Posted on Dec 29, 2009
SOURCE: manual for westinghouse lt959s
Hi, our lt959 is tripping the power mid cycle. just wondering if any one can help...
Posted on May 25, 2010
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
MVWX550XW wont start Lid wont lock
There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | Maytag MVWX550XW Washer
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Sep 09, 2010 | LG WFT1071TP Top Load Washer
Manual for westinghouse lt959s
Dec 18, 2009 | Creda Washing Machines
The small metal piece on the lid rusted and broke away so now even when the lid of the washing machine is closed, the machine won't start because ti can't detect the lid as closed. What can I do?
You can bypass the switch by jambing something in there and this will allow it to spin with the lid open or closed but please keep the lid closed at all times while washing.
Oct 31, 2009 | Washing Machines
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Jun 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Ge spacemaker
check power at the receptacle make sure you have 240v
May 11, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
It wont finish washing
open and close the lid a few times. can you hear any clicking noises, you should hear the lid engaging the lid switch. if the machine doent think lid is closed it wont funtion( safety reasons)
Feb 27, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine
sounds lilke a bed lid switch for safety reasons it wont spin if it thinks the lid is not closed. open nd close the lid carefully agian and again, as your doing it do you hear a clicking noise??? if not your not contacting lid switch
Feb 25, 2008 | Whirlpool LSR6334LQ Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
