Question about Sony FD Trinitron KV-28FQ75 28" TV
Sony kd28dx40u After about half hour of my tv being on, my tv makes a cracking sound so bad that you can't hear the people on tv speaking. After switching tv off for a while then putting it back on it is ok for a while then it starts cracking again. What could be wrong with my tv as it is only three years old.
  • kjrossignol Dec 31, 2008
    I just bought a new HDTV. It is making a cracking sound. I had an electrican look at my wiring and there is no problem there. He then suggested I get a new cable box, which I have now replaced and still the TV makes a cracking noise every so often. Any suggestions? Could it be a fault with the TV or possible the cable line coming into my house? Also, 6 mths ago I had an older analog TV that made the same sound and I sold it at a yard sale thinking their was something wrong with the TV.
    Novelist:
    Champion:
  • 275 Answers
It seems that there is EHT Leakage from the EHT Transformer Anode Cap! Generally happens during rainy seasons, or if your TV is placed near a window or near an AC, due to excess of moisture in the air. Unplug the TV and wait for an hour to discharge all residual charge in Capacitors. Open the back, and look for a thick red cable leading from the FBT. (It is a Black Block with a thick red cable running from it to the rear of the Picture Tube). Take a sturdy Electrical cable with the conductor visible at both ends. (Multimeter Leads will do.) Now, ground one end of this lead to any Metal part of the Chassis, and gently ease the other end under the Cap of the EHT Cable. BE VERY CAREFUL, as there are very High Voltages involved! Do it Gently, and you will hear a POP! This indicates that the Electrical Charge inside tha Picture has been discharged. Now Take dry cloth and wipe clean the area around the Anode Cap. Close the back of the TV, and switch it ON. In all likelihood your problem should be resolved. BUT, I REPEAT, DO NOT DO THIS UNLESS YOU KNOW WHAT YOU ARE DOING, AND ARE VERY VERY CAREFUL. Otherwise, seek professional help!
Posted on Aug 02, 2006
Why would our Samsung MN HL 850 86W make a crackling noise after it warms up? It sounds like the cracking of a fire. What could it be?
Your lamp ballast is going bad. Might last a few more months, but eventually it will have to be replaced. Bulb will also likely have to be replaced at same time, but try the ballast first.
May 04, 2014 | Samsung HL-S5086W 50" HDTV
The receiver is hooked through my Blue Ray Disc Player via HDMI cables. When watching a movie the sound is way to overbearing on the effects end making it almost impossible to hear any speaking voices. ...
I'm not sure if this will help you but if you can hook your Bluray player directly to TV(HDMI) then out from TV to reciever via HDMI or digital optical, it very well may solve your problem.
Apr 28, 2011 | Sony STR-DG820 Receiver
Realy chattering in Sony WEGA Trinitron
Hi, that is probly a capacitor in the power supply section near the relay, he failed to keep it charged
whit a good capacitor tester wizard you must be able to find and check for cracked soldering around it or directly on the relays
good luck and hope that will help you/
that is not an expensive repair;half or 1 hr time....
Mar 30, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
People can hear me speak but I can't hear them
Sound inducers do go bad. Normal the same audio amplifier is used for both the ear piece and the speaker. Since the speak does work, it sounds like the ear piece has died.
May 28, 2009 | Lands Phones
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
No audio
9 times out of 10 a TV like that which has no audio is fine and the audio settings are not right or it is a cable box / satellite receiver problem. If you are using cable then connect the cable directly to the TV, tune in an active channel and set the volume about half way. If you do not hear any sound then, using the remote, go into the menu, scroll to the audio page and make sure the speakers are not set to OFF and also make sure the audio is not set to SAP. If you have checked all that and everything is set correctly and you still have no audio, then your audio output IC is probably bad or cracked and should be resoldered or replaced by a qualified tech.
Jul 30, 2007 | Sony KP-53V75 53" Rear Projection...
Sony FD Trinitron KV-28FQ75 28" TV Logo
532 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
