Question about Kenmore Dryers
Wont heat it is gas but just wont heat
    President:
  • 2,468 Answers
Do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
Posted on Feb 08, 2012
My dryer ia crosley and wont heat,the clothes wont dry,she activate but dont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 22, 2011 | Dryers
The dryer heats up the first time it starts but wont heat up again i can see the glowing red from the element but the burner wont light
heatman101./,'
Jul 01, 2011 | Whirlpool 78532 Gas Dryer
Dryer wont trun off wont heat at all
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Dryers
The dryer wont dry. it wont heat up
heatman101
+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_
Jan 31, 2011 | Roper REX4634KQ Electric Dryer
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
heatman101
l;
Jan 03, 2011 | Roper RGX4634KQ Gas Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Gas dryer heats then wont heat?
Bad ignitor most likely. Has a hair line crack, and yields an iffy contact.
Jun 21, 2010 | Maytag MDG2706A Gas Dryer
My frigidaire electric dryer wont heat up, only
heatman101
May 11, 2010 | Dryers
It wont heat
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 09, 2010 | Dryers
Wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
kllk
Aug 03, 2009 | Roper RGX4634KQ Gas Dryer
Dryers Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
