Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
WHY DOES MY RIDING MOWER CRANK BUT WONT STAY STARTED
MODEL-917.276221 I'VE REPLACED THE FUEL LINES, FUEL FILTER, NEW SPARK PLUGS, NEW BATTERY, NEW SOLENOID, AND FRESH GAS. IT KEEPS TURNING BUT WILL NOT START. IF I KEEP SPRAYING STARTER FLUID THEN IT'LL KEEP RUNNING BUT ONCE I STOP IT DIES.
rockitman187
  • 2559 Answers
SOURCE: Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Posted on Apr 05, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 468 Answers
SOURCE: mower engine turns over slow even with a fresh
A solenoid isn't likely. If you want to test, you can try jumping the two big terminals on the solenoid and see if it turns faster. If not, you know it isn't the solenoid. Next thing you'll want to check out is the battery connections, and the connection from the solenoid to the starter. These are more likely to cause your problem due to poor conductivity, or loose connections. Take each one loose, and clean it up with a wire brush, then put them back on. Make sure you check the one that hooks to the starter itsself, as the vibration from the mower likes to shake them loose. If you have checked all the connections, and you still haven't found the problem, you'll want to check the starter, as it could be getting weak.
Posted on Mar 28, 2010
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
G'day, I have a simplicity express ride on mower that was running when I got it, I've put a new battery in it, new spark plug, new fuel filter and new fuel lines. Last time I used it was running great
that video sounded like a very low battery, and, if you know your not getting spark, check the plug wires for continuity, and that there are good connection to spark plugs, once you get spark, then make sure you are getting fuel
Mar 09, 2013 | Garden
95 Park Avenue Ultra dies for no reason I can find, I've replaced the crank sensor, cam ssensor, spark module, fuel filter, I've had the injectors tested, fuel pump tested, plugs & wires t
As you have probably figured out by now, you will have to treat it as a no start and troubleshoot it when it fails to start. Until you figure out if you are loosing spark or fuel to the injectors when the engine dies you have no direction to go in.
Aug 20, 2012 | Buick Cars & Trucks
Riding mower fuel starvation
sounds like you will need to rebuild you carb.
Jun 29, 2012 | Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
I HAVE A POULAN MOWER TRACTOR MODEL HD12538B THAT WILL NOT CRANK. I HAVE JUMPED THE BATTERY WITH THE CAR, REPLACED THE SOLENOID AND THE IGNITION SWITCH. i HAVE ALSO JUMPED THE STARTER AND IT WILL CRANK...
Try replacing your spark plugs. Make sure its getting gas. Make sure your air filter is nice and clean. Check your fuel filter. and if all those fail try replacing your coil.
Feb 07, 2011 | Poulan Garden
Cranks but won't start after we replaced one broken belt below deck
try different spark plugs. sometimes because they are new doesn't mean they are good. check the bottom of the old plugs for raw fuel.
May 24, 2009 | Craftsman Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
139 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
