Question about Hamilton Beach 80374 Custom Grind Deluxe Coffee Grinder
80674 grinder doesn't turn on or off
Moving the cap latch helps, but I cannot get the grinder to work with the cap on
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I purchased a GE coffee grinder about 6 months back. Used it about 5 times. The on light comes on but the grinder doesn't work? Need help!
Check the connection at the relay.
Check that around 12-24 volts is present at the relay (the wire goes from control board to relay).
If its present then check 120-140v present at the other terminal of relay.
If both is true then unplugg the grinder from main board.Isolate the motor from all the wires and check the coil resistance.(zero resistance conclude that motor is bad).
Thanks
please rate my work
Sep 11, 2011 | Coffee Makers & Espresso Machines
Coffee grinder ge model no.111338 .Power light is ON but the grinder doesn't work.
check the rley is in good condition.(by unplugging all the wires and check the continuity between the terminals).
second by checking the grinder coil resistance that its not showing open .
third might be something stuccked in the grinder.(rarely)
thanks
please rate my work
Aug 06, 2011 | Coffee Makers & Espresso Machines
I have Barista grinder. I've had grinder for about 3-4 years and it stop moving. I unplugged cord, tried to turn the feeder and plugged in still not moving except timer is clicking. I wonder why it...
Hi It could be the timer switch but if you hear the timer move(whirring) it is probably OK. There is a thermal fuse on the motor that will go out and you just have to replace the thermal fuse. Its under the wrap on the side of the motor. Which grinder do you have?
Jul 07, 2011 | Starbucks Barista Burr Grinder
Ginder doesn't turn on.
Possibly the Safety Switch is not properly activated. Make sure device lid is in the correct position or the unit will not start.
Please vote if my information is helpful or not. Recommended. Thanks UAW Local 974.
Jun 26, 2011 | DeLonghi DCG2C Electric Blades Grinder
How to disassemble it to fix the start button, which fell into the machine
Just adding to dhelkamp's instructions (which helped me immensely!).
The front quantity knob kan be pulled right out - it's held in place by friction only.
The side knob has 3 latches holding it in place. Releasing 2 is sufficient. Use 2 small flat screwdrivers.
As for the assembly, there are 4 latches in the inner assembly holding it in place. The location of these latches can be seen by looking at the edge of the outer shell. The front latches are just behind the holes for the rubber feet, and the rear latches are just in front of the rear holes. Use a flat screwdriver to release one of the front latches, while pressing down on the outer shell - it should give way 1-2 mm. Repeat on each of the other 3 latches, whilst keeping pressure on the outer shell. The cover should easily slide off the grinder assembly. Beware of getting pinched!
Jul 26, 2008 | Krups GVX2-12 Electric Burr Grinder
Hamilton Beach 80374 Custom Grind Deluxe Coffee Grinder Logo
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
