Question about Lincoln Ranger 250 Gxt Welder Generator K23824
Auto feed stopped - Lincoln Ranger 250 Gxt Welder Generator K23824
    Genius:
  • 1,212 Answers
Check fuses first, then Check the 24 volt relay for function. If it makes contact, the problem is likely the SCRs on the control board have failed.
Posted on Feb 08, 2012
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
My worx trimmer line does not feed
According to the manual it only advances 1/2" so if 4" break off, you have to start/stop 8 times.
May 25, 2012 | Worx GT WG150 10 in. 18 Volt Cordless...
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Cannon imageclass d660 auto feed stopping 3/4 way through
There are some small plastic pieces in this feed that can do this. This is an older machine, the whole top feeder can be replaced for $150.00 Its $100.00 dealer cost. And they will want an hours labor.
If that doesnt sound good I would buy a new machine.
Dec 23, 2008 | Office Equipment & Supplies
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Lincoln Ranger 250 Gxt Welder Generator K23824 Logo
65 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
