Question about Indesit Washing Machines
How do I fit a replacement door seal on an Idesit 2256E washing machine
    Genius:
  • 1,550 Answers
I think manual will be helpful to do this .
Posted on Oct 22, 2008
  • SAM ANDERSON Oct 22, 2008
    If you dont have a manual
    Follow this steps:
    Power off, Remove the machine top, push drum towards the rear of
    machine and look down to where the door seal attaches to the drum . You
    should seen another clamping band. Unscrew this inner drum clamping
    band and pull the door seal away. Ensure the
    seal is located correctly and refit both outer and inner clamping
    devices. If seal is obstructed by concrete weights the front panel and
    the concrete weight will have to be removed before seal can be
    detached. If the clamps cannot be reused, go to an electrical store to buy the longest cable clips available.
    Two or more clips can be connected together to form one long clip which
    can go round the inner part of the doors seal to hold it in place on the
    drum lip.
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Jun 27, 2012 | Beko WM5140W
How to remove door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko Complete Door Wm1510w 2816000500 Wma10w Wm1510w washing machine How to Replace Beko washing Machine Door Seal
Apr 24, 2012 | Beko Complete Door Wm1510w 2816000500...
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
Washing machine door seal replaced and door won't close
Could be you have not got the door seal fitted correctly around the front of the cabinet porthole, and make sure the retaining clamp is fitted correctly.
Mar 24, 2010 | Washing Machines
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Replacement door seal/gasket
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Apr 08, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
37 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
