Question about Singer Quantum XL-6000 Computerized Sewing Machine
Automatic treader stop working
My automatic treader will not grab the tread on the top. Any suggestions on what could be the problem?
  • Singer Master
  • 7,365 Answers
Could it be bent? could it be loose?
Posted on Feb 08, 2012
My bottom thread has lots of loops. I have checked the top threading, my needle has not been bent, top and bottom threads are the same weight, the presser foot is up when I thread the machine.
indicates bird nesting and is the result of the needle tread not being tight enough
tension it up more and sew scrap material until you get it right
Jan 20, 2018 | Sewing Machines
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Requesting support: juki HZL F6000 suddenly stopped sewing straight stitching in a straight line. Also stopped automatic treading.
the machine may need to be serviced, the needle bar may need adjusting, also could be something wrong with the motherboard
Dec 08, 2014 | Juki Sewing Machines
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
My singer 4423 wont pick up the bobin tread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
if these suggestion don't help,,then the machine needs to be
checked by a sewing machine technican to see if it's out of time
Jul 31, 2012 | Singer 4423 Sewing Machine
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
Bernina Deco 650 Check if upper or lower thread is cut shows on
turn machine off and on to see if message clears... not sure for that machine ( I work with Brother products) but if it has a wiper (small hook shaped blade) that trims the tread automatically it may be stuck in the extended position
Apr 08, 2010 | Bernina Bernette Deco 600
Automatic bobbin winder does not stop when bobbin is full
Simply loosen the screw on the bobbin winder stop, no more than 1 full turn or you will drop the backing nut will fall down into your machine, move the bobbin winder stop slightly to the left then tighten the screw and see if that works. you may have to repeat this step several times until you find the right spot to stop the bobbin at the correct point.
Jun 27, 2009 | PfaFF Creative 7570
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Authomatic treader part ellure
If its under warranty.... take back to Granny's
Baby locks are Wonderful!!! but the dealers are picky about whom repairs them, let the experts fix your baby.(after all you'd take your Porche in for service under warranty wouldn't you?)
Just my
Jan 17, 2009 | Baby Lock Ellure
Singer Quantum XL-6000 Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
