Question about Air Tools & Compressors
Paint spray nozzle - how do I know which nozzle is which - external mix or internal mix?
My sprayer has two nozzles, one is for Internal mix pressure, and the other is for External mix pressure. How do I know which is which?
    Scholar:
  • 107 Answers
Top one should be paint flow and the bottom one should be air flow. that is how my gun works anyway. Hope this helps you out. mine is a siphon type gun may be different for a gravity gun. Mike
Posted on Jan 06, 2009
Getting sprayer to spray something other than air
Is the tube connected to the nozzle going into the paint or fluid?
Aug 23, 2017 | Air Tools & Compressors
Spray can won't spray how to fix
Pull the nozzle straight up and out. Grab a nozzle from another can that looks to be the same and try that one. You may have to try multiple nozzles. You can also buy nozzles on ebay, but they are usually more than the price of the can.
If this doesn't work, then the can may be faulty, or if very old (many years) it may no longer have pressure even though there's still paint inside.
Another thing to check is if the ball inside rattles when you shake the can. If it doesn't, the paint might be hardened in the can.
Remember next time you finish painting to wipe off the nozzle, turn the can upside down and spray until almost no more paint is seen.
Sep 27, 2016 | Rustoleum Rust-Oleum - 1685830 - Spray...
Paint cup wont release from nozzle
My suggestion is to soak your sprayer in warm soapy water for 10 to 15 minutes and then try and unscrew it. I think that should soften the paint up enough to do the job,.
Aug 23, 2015 | Wagner Spray Tech PAINT READY SPRAYER
How much should I thin paint for pneumatc sprayer?
you did not mention what paint, you did not mention what sprayer.
remember, if you use solvent - opacity of the paint is sacrified, tints are less visible, metallic require more clear coverage.
for water based paints - except airbrush, usually no thinning is required, but you need to first stir it well (at least 3min on manual or 1min 30sec if mechanical stirer is used) strain it, i am using old stockings for that purpose in single layer, works very well for me and if nozzle is above 1.4mm up to 2.8mm there is no problem whatsoever. if this is splatter paint (nozzle 4.5mm or greater) do not even think about thinning it...
for acrylic - if nozzle is between 0.8mm and 2.8mm, procedure as above and you need to add specific thinner, usually up to 20% albeit in some cases up to 40% per volume) so paint will be about like ight cooking oil - water.
for oil paints and enamels - solvent should be not more than 20%, albeit you can increase it up to 40% in rare circumstances, if you are using hvlp gun, you can, if you yousing hp gun - no! it will disperse too much.
for two packs and urethanes - not more than 20% better keep between 5% and 10%
for latex - in rare circumstances you are allowed to use very, VERY specific solvent, and ususally not more than 10%, nozzle usually is 8mm or greater in these paints.
Oct 19, 2014 | Air Tools & Compressors
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
I have a wagner hvlp control sprayer and it will not spray out the paint from nozzle? why? it is not clogged???
On my Wagoner sprayer, it is possible to turn the nozzle 180 degrees to clear it. Does yours have this feature? I thought my sprayer was faulty (being very cool myself, I didn't read the instructions) maybe due to non use or age as it has sat on the shelf for two years since last use. I bran out and bought another one. After about 10 minutes of use, the new one stopped. I cleaned and cleared and still had no luck. I bought pipe cleaner and little brushes ... you wouldn't believe all the trouble I went to to make sure the nozzle was clear. I was convinced the trouble was with the motor and not the nozzle. Then, I read the instructions ... they said to turn my nozzle 180 degrees and pull the trigger - IT WORKED!)
If yours will not spray, there is a motor trouble or there is a clog somewhere between where the paint is and the nozzle. Believe this and believe that the sprayer was made to work and it was not made to not work and you will discover your trouble.
Thanks for your question ... I hope I have provided some insight for you.
Jun 20, 2011 | Garden
Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Dec 28, 2009 | Air Tools & Compressors
Kirby paint sprayer attachment
HERE is the manual, just instead of shampoo use water-based paint and do nut put that nozzle on the sprayer. WASH IT WELL after you use it. Honestly - you better off buying a spray can. Painting with Kirby - MESSY. May sound strange from someone who makes living selling Kirby stuff but I just hate salespeople making it sound as if Kirby vacuum is ONLY appliance that you ever need to buy...
Rocky
Apr 25, 2009 | Kirby G5 Bagged Upright Vacuum
Air Tools & Compressors Logo
756 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
