Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
I am looking for a repair manual for a Rascal 305
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
Feb 15, 2016 | Electric Health & Beauty
Rascal 305 mobility scooter that when you push the lever to drive the seat goes up.
Sounds like the electrics need checking over. you need to take to a service centre to check unless you know what has caused this to go wrong in the first place.
May 28, 2015 | Health & Beauty
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
Where is the circuit breaker on a rascal 305 scooter?
You should be able to follow the battery lines to it..
Have you checked the freewheel lever to ensure it is engaged?
Aug 23, 2014 | Health & Beauty
Rascal 305
Check for "stuff" binding axles, make sure all connections are tight, lubricate everything.
Apr 11, 2014 | Health & Beauty
Rascal 600T Scooter FIX IT Manual
There is an owners manual available which has a troubleshooting guide at the following: http://manuals.monsterscooterparts.com/mobility/Rascal/manual-rascal-600-t.pdf
If you have a good relationship with a local dealer they may be able to copy and provide you with one.
Electric Mobility, the manufacturer, in my experience will not provide one to you.
Mar 02, 2014 | Electric Mobility 3 Wheel Motorized...
Rascal 305
hold home volume down and power button for 15 seconds
chect the pover button under the case is not broken
Sep 23, 2013 | Nokia 305 Asha Dualband Dual SIM Unlocked...
3 wheel rascal 600 blinks 4 - 8 times...what does it mean?
Good day to you.These series or blinks or bleeps are codes to determine the fault.& the trouble you will find is Shoprider etc will not give out info to the public.Contacting a Scooter repair shop is a good idea,reason being.They can order your part if needed.You can also download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File,if you do anything yourself.Remember a repair shop will be hesitant to even look at it & I suggest you take a photo of every step if fixing yourself with your mobile.Have a nice day,hope I was of help.Colin
Mar 31, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Where can i find a user manual for a liteway3 mobility scooter
Kain I looked under the Golden Technology website and couldn't find a manual for that scooter. Now in the UK Rascal sells a liteway3 scooter also so I don't know if you have the Golden version or the Rascal version. To contact olden Tech Support call their Technical Service Department, 1-800-624-6374 Hope this helps you
Sep 21, 2010 | Health & Beauty
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
250 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
