Question about Xerox 6500N Printer
Where is waste container on xerox 6500
2 Suggested Answers
njau
  • 15 Answers
SOURCE: How do I change the waste filter on a Xerox 5030/5050?
hi, open the front door, release the drum latch,open the metallic plate next to the front door then remove the waste toner bottle
Posted on Nov 16, 2009
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
Which toner Dry Ink Waste
The dry ink waste container is located behind the front panel in the lower left area. Only the handle shows, it is about 18" long.
The other waste container that is clearly visible when you open the front panel is the developer waste container.
Apr 12, 2010 | Xerox DocuColor 12 Printer
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Feb 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
All the lights are red & nothing will print
Is the waste toner cartridge full? If so you can vacuum out the waste toner and re-use the container. The waste container is on the left hand side with the front flap down.
Dec 18, 2009 | Xerox Phaser 6110 Laser Printer
Nov 09, 2009 | Xerox WorkCentre M-24 Color Copier
Phaser 7300N - Where is the waste toner container?
That machine does not have a waste toner container like the xerox phaser 7400. What it does is all the waste toner is cleaned at the IBT belt. If you remove your IBT belt part number 016-2000-00 you will see there is a plastic container at the end and that is where the wast toner is.
Oct 13, 2009 | Xerox Phaser 7300DN Laser Printer
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Xerox 6500N Printer Logo
187 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
