Question about Panasonic WORKiO DP-C262 Printer
Error code e4-11 right cover fan rotation - Panasonic WORKiO DP-C262 Printer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Please check out the fan rotation
Posted on Mar 05, 2015
Help error code upside down F E can you help
FE ERROR IS FAN MOTOR FOR DRYER HAS PROBLEM, TRY TO OPEN THE TOP COVER AND YOU WILL SEE HOW TO CHECK AND REMOVE THE FAN MOTOR TRY IT TO ROTATE BY YOUR HAND ND TESTING AGAIN(STOCK-UP) IF THE SAME PROBLEM STILL OCCUR CHECK THE VOLTAGE OF THE FAN MOTOR BASE ON HIS REQUIREMENT IF YOU KNOW HOW TO CHECK IT, IF THE VOLTAGE IS RIGHT YOU NEED TO REPLACED THE FAN MOTOR ASSY.
Mar 11, 2015 | Kenmore Front Load Washer
Ir5000 error codes E804 -0000
dc power supply fan. open the left covers and you will see the dc power supply in that board you got fan. and switch on the m/c if it's rotating.
Jan 11, 2013 | Canon CLC 1120 Color Copier
Error code 57.1
Fan not rotating, open top & feft cover, manually rotate it, is it free or jammed ?,if its jammed,remove the fan, lubricate it or replace it.. check fan connector.
Sep 12, 2011 | HP LaserJet 5100dtn Printer
My Panasonic heat pump HE9LKE (flagship model), stopped working last weekend, and after 'check' gave off an H97 error code. "Check the outside fan". It was freezing outside, and both front and...
H97- Outdoor fan lock abnormality. Check fan motor rotate freely. If hard replace bearings or motor. If rotate freely, out door PCB faulty. Replace it.Helpful?
Jan 24, 2011 | Heating & Cooling
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
Canon imagerunner 5000i -error e000121-000 what is the problem?
E-121 refers to the Controller cooling Fan (FM4). The fan is dead, or perhaps something is blocking it and preventing rotation. There could also be a short or open in the circuit. Fan vents on the right rear side of the copier. (Facing the front). If the back cover is removed the fan is located (Facing Rear) at the left side of the machine next to the Main Controller Box. Try blowing out the fan it may be plugged with dust Bunnies.
Mar 22, 2010 | Canon imageRUNNER 5000 Copier
E50a10 blinks four times
Four blinks is a fan rotation error code which means one of the four fans is not operating properly. Check these fans and replace any found defective.
  • Remove the lamp cover.
  • Remove the rear cover by removing the 13 screws holding it in place.
  • Check the fans.
053bd7d.jpgLocation of fans 1 and 2
Location of fans 3 and 4
Dec 07, 2009 | Televison & Video
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Getting system error E805
E805 (The fan rotation is faulty.)
If no detail code is indicated, suspect the feeder fan (FM1) or the reversing guide cooling fan (FM9). Is the connection of these fans normal? Is the drive signal of the fan identified in the previous step about 22 VDC while the fan is rotating or about 12 VDC otherwise?
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Sep 16, 2008 | Canon Office Equipment & Supplies
Panasonic WORKiO DP-C262 Printer Logo
77 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
