Lacie hard drive 500gb
Hello I've got a lacie 500gb hd that won't stop flashing the blue light and won't appear on the desktop anymore. I have others connected with no problem. Please could you help.
thanks
cheers al formatearlo se me fue guardar el sonido
  • 77 Answers
THE CARD CONNECTED TO HD MAY BE NOT FUNCTIONING OR THE HD MAY BE HAVING PROBLEM OR CONNECT PROPERLY THE HD CARD
Posted on Apr 07, 2009
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Sep 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
Nov 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Ther is no problam remove from the system and re fit the drive this type of opration do rarley but dont do regulary only some times
Jul 17, 2008 | LaCie Computers & Internet
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie drive does not come on
Maybe the usb chip in the hard drive enclosure that converts ide into usb failed. You could replace the enclosure (they sell enclosures at best buy) but it could be quite a hassle.
Jan 04, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
116 people viewed this question
 Grubhead
Grubhead
