Question about OCE Office Equipment & Supplies
What is error code C440 on an Oce IM2330?
Copier has C440 when you turn it on.
  • Orion Richardson
    Orion Richardson Feb 07, 2012
    The code is C440 on a Oce IM 2330
  • 149 Answers
The fixing unithas an overheat error, It needs parts replaced
Posted on Jun 15, 2014
frcs68
  • 1605 Answers
SOURCE: OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Posted on Oct 17, 2008
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 3230 Answers
SOURCE: 0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Posted on Jul 24, 2009
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 30 Answers
SOURCE: I got a C440 error code sub code "7" with Toshiba
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Posted on Aug 14, 2010
Model 233. What does error code C440 indicate?
C440 error indicates a fuser temp too high or too low. SOMETIMES it's random and can be reset by 1. hold down the 0 and 8 keys while turning on power. 2. Enter 400 press Start. 3. Enter 0 press Set or enter. Copier will begin warm up mode. If the code recurs, you will need the fuser unit rebuilt or replaced.
Oct 04, 2015 | Toshiba Office Equipment & Supplies
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
C440 error
chik tha power suppl bord
Nov 15, 2013 | Toshiba E-Studio 456 Copier
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
We have the Oce im2330 for our small business. It was working fine until a couple weeks ago when I powered it on and it went from warming up to call for service error code F103. I would like to try to fix...
The operating system for this machine is stored on the hard drive, so even if you replace the hard drive you would have to have access to the propietary programming for the machine. You need to call for service 1 800 243 5556. Sorry.
Nov 27, 2009 | Office Equipment & Supplies
I have an imagistics copier zc55 and I'm getting an error code C-12C6 when I start it up. Where can I get information on what this is.
Turn the copier off and on. If the error comes back, there is a problem with the image processing board. Call Oce for service 1 800 243 5556
Oct 08, 2009 | OCE Office Equipment & Supplies
What is error code 06112 ?
oce is a variety of different model of copier send me the picture of your copier then i can tell what model is it and what is the real problem low_toner@yahoo.com
Aug 06, 2009 | OCE Office Equipment & Supplies
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
418 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
