Question about Lenovo 3000 G530 PC Notebook
Screen is blank how do I get it to work again
I was testing a second monitor and I unplugged the monitor cable while the monitor was on right b4 shutting down my laptop. And the next time I tuned my laptop on the screen never displayed anything nothing not even the boot menu. The laptop is on but blank screen
  • 734 Answers
Do you need the external monitor to switch it back to internal monitor or both on?
Posted on Feb 08, 2012
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Monitor will not stay on
    HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
    Jul 02, 2009 | Computers & Internet
    Monitor screens blanks a few seconds after I switch on computer
    Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
    Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
    Screen works for awhile but then goes blank.
    if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
    ekwhoward@yahoo.com.
    Thanks
    Ekow
    Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
    Dell172fpb 17" monitor
    Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
    1. Turn off both your computer and the monitor.
    2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
    3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
    4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
    Thanks
    proton
    Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
    Monitor displays properly then screen goes blank
    it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
    Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
    KDS monitor screen goes blank.when you shut it off & turn it back on it goes blank again within a few seconds.
    make sure all the cables are secure... by unplugging and re-plugging them back in. Does the monitor feel very hot in the back or on top? If so unplug the monitor and tip it upside down to make sure nothing metal fell inside.
    Apr 30, 2008 | Computers & Internet
    Screen displays fine for a second, then goes blank
    Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
    Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
    Bank Monitor problems
    Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
    Jul 09, 2007 | Dell E193FP 19" LCD Monitor
    Lenovo 3000 G530 PC Notebook Logo
    137 people viewed this question
    Top Lenovo Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
