The display of my boss bv 9974 is too dark!!
The display is too dark and it appears as if it were a negative picture in some parts of the screen!! What can I do? Thank is advance! Soon Daniel
  • 442 Answers
If the display is too dark from the start, that is from the point you get the compaq logo then the issue should be with the LCD panel. if it is dark only in windows you can try increasing the brightness by using the Fn Key and the brightness up option in the keypad.
Posted on Feb 08, 2012
I have jvc av-27020 volume and channels display appears normal on the screen but the picture is dark, help to solve it
Volunteers and Chan display ate digital inputs. On a CRT TV the picture is an analog input. A dark picture generally means that the EHT supply is low or the picture tube is getting old ending it's useful life, solution is not easy
Jun 03, 2014 | Televison & Video
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
Backlight very low making screen dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Oct 29, 2009 | Acer TravelMate 4200 Notebook
My screen is dark, totaly black, what should I do ?
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | Everex StepNote VA2000T Notebook PC
Boots up then just goes to a dark screen
www.lcdparts.net
Sep 26, 2009 | HP Compaq nc6000 Notebook
Nokia n95 dark hazy negative like display on & off after pressed
your phone need a general service. please contact service technician
Sep 22, 2009 | Nokia N95 Cellular Phone
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 21, 2009 | MSI M670 Notebook
Display
try to remove ur display driver and reinstall it
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Camera not displaying image
after taking pictur. picture appear small or, technicolor screen
Jun 15, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
