Question about HP DeskJet 895cxi InkJet Printer
States out of paper but does have paper In HP deskjet 895CXi printer
I have a HPdeskjet 895CXi printer and it states that it is out of paper but it has paper in it but it will not print.
    Problem Solver:
  • 12 Answers
Solution
Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent. NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Tap the stack of paper on a flat surface to align the edges.
  3. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  4. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  5. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driverThe paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
Posted on Oct 22, 2008
My hp deskjet 895cxi has worked so well for years
probably clogged nozzles. Clean the print head. If that doesnt work, replace the cartridge with a new one
Jul 23, 2010 | HP DeskJet 895cxi InkJet Printer
Want to install my hpdeskjet 895cxi on a pc
You can download the printer software from this link, just select the operating system that your computer is using and when you're done downloading the software you just run it and follow the wizard in installing the printer.....
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=59306&lang=en&
Jan 05, 2010 | HP DeskJet 895cxi InkJet Printer
I have a HPdeskjet 5550 printer. While printing,
Have you tried switching off the printer and then starting after sometime
Dec 09, 2009 | HP DeskJet 5550 InkJet Printer
Problem with Deskjet 895cxi
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Nov 08, 2009 | HP DeskJet 895cxi InkJet Printer
Envelope jam
Tweezers. There could still be some small piece of paper under a sensor somewhere. Get a torch and dive in! Pull it apart Nothing to loose
Apr 06, 2009 | HP DeskJet 6840 InkJet Printer
HPdeskjet 842c printer paper pickup
Paper lift mechanism is broken. It's uneconomical to have repaired, sorry.
Jan 22, 2009 | HP DeskJet 842c InkJet Printer
Hp 896 cse. The paper feed is not working.
Can you get to the pick up roller? is it putting out paper at all? Clean the roller with a cotton swab and rubbing or denatured alcohol. Sometimes paper dust will build up on the roller and it cant grab the paper. All check and see that the roller is trying to turn. RUle out mechanical failure.
Dec 11, 2008 | HP DeskJet 895cxi InkJet Printer
HP DeskJet 895cxi InkJet Printer Logo
242 people viewed this question
Seeker5211
Seeker5211
