Question about GPS
Fagor boiler flashing F11 and spanner symbol
My Fagor boiler is flashing F11 and spanne symbol on the display. What does it mean?
SOURCE: holden barina 2003
it means its due for service. If u wanna get rid of it without servicing the vehicle then as you start the car simultaneously push the ODOMETER reset button on the dash and it will wipe it. This will however just delay the point your car needs servicing.
Posted on Jun 28, 2008
SOURCE: peugeot
It means it's time for it to be serviced.
http://www.peugeotdiesel.com/Reset_Service_Light.html
Posted on Oct 12, 2008
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
  • 2309 Answers
SOURCE: My Citroen Saxo is showing a spanner symbol in the
service engine ie oil change
Posted on Nov 16, 2009
Testimonial: "Thanks for the quick response. Excellent feedback."
SOURCE: It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Posted on Nov 01, 2010
Spanner symbol has appeared on dashboard display .
service due or fault code that needs attention
run the fault codes to determine if there is a problem
Sep 09, 2017 | Cars & Trucks
Vaillant ecotec plus 824 problems
The Symbols should be there whenever the boiler is in use, it confirms the pump is running and the gas valve is open...i.e firing.
the pump overrun may come on after a firing to dissipate excess heat and is what it says, i.e the pump continues to run to keep the hot water moving to prevent the boiler from getting noisey. Sometimes you may see a radiator symbol which means the boiler is doing a 'heating' cycle as against hot water.
Nov 20, 2013 | Computers & Internet
Pressure cooker controls. what do the 3 symbols on top mean on the fagor pressure cooker
The circle with a slash through it means that you can remove the valve, the little cloud spraying means pressure release and the next symbol, or numbers, indicated pressure.
You can get a more detailed description in the manual for your pressure cooker, which you can find here:
http://www.hippressurecooking.com/category/fagor/
Mar 11, 2011 | Vacuums
Hi....f 13 is flashing on the machine and a red spanner symbol is on all the time, also unable to open machine even after draining it manually... thanks for any help you can offer.
You did not say what machine you have!
F 13 I have is a dispenser circuit error and the causes/procedures are
1 Unplug the washer or disconnect power
2 Check the mechanical linkage from the motor to the top of the dispenser
3 Check the wire harness to the dispenser motor and the central control unit
4 Check the dispenser motor for powered rotations
Replace faulty components
If there is a spanner symbol lit it means you need to call a repairman.
Feb 17, 2011 | Washing Machines
Apr 01, 2010 | Whirlpool Washing Machines
Help
This means your drum cartridge is close to expiring and will need replaced.
Open front cover lift out cartridge by the big green handle install new one after removing all packing materials-see instructions included with new drum/transfer kit.
Jun 20, 2008 | HP LaserJet 2550Ln Printer
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
