Fridgidaire crws5700as0 top loader will drain and agitate, but freezes on spin. When I am able to get it to spin it sometimes makes extremely loud scraping noise near the transmission. It smoked pretty bad which is how I discovered the problem. I can manually move the tub in one direction but not the other. Belt seems to look fine, and if I can get it to move, the gear under the transmission is extremely hard to turn one direction.
docjohn174
  • 943 Answers
SOURCE: Won't agitate and makes a grinding noise
hi thanks for the question yes it is a bad transmission sorry
Posted on Sep 26, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
localwonder
  • 6784 Answers
SOURCE: Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Posted on May 21, 2009
  • 731 Answers
SOURCE: I have a WLSR3000. It was recently moved. It is
Exploded views of your machine with part number and all can be ordered from Sears
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WLSR3000G6WW/0432/0153200?searchedModel=WLSR3000&blt=
Posted on Feb 05, 2011
tunde007
  • 2382 Answers
SOURCE: ge washing machine spins fine
Hi, the outer tub is fixed to the body of the washing machine and holds the inner tub. The outer tub enables the inner tub to move without hitting any other mechanism in the machine. You probably have a bad bearing which is why the outer tub moves and scrape the buttom when agitating..
Posted on May 09, 2011
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Performa Top Load Heavy duty (PAV1000AWW) has a loud noice when it is spinning. Just changed the belt but still extremely loud when spinning...any suggestions>
Thanks for choosing FixYa and welcome to the site. Anytime you have noise while spending, loud thumps and noises, it can almost always be traced back to the drive motor. This is what allows the washer to spin, drain, and agitate. You need to check this out first and check your spin bearing as well. I would say one or the other is the reason for your noise.
Apr 26, 2011 | Maytag Washing Machines
I have an RAX4232PQ Top Loading washing machine. It fills up with water and it drains but it won't spin. It only makes a loud humming noise when the spin cycle is on. Last time it did that there was a...
This problem is commonly caused by a broken motor coupling. Whirlpool manufactured top loaders (such as Kenmore, Roper, Estate, Fridgidaire and later model Maytags) all utilize a motor coupling instead of a drive belt. This configuration is known as a "direct-drive" system. The motor coupling wears with age and can break over time. The usual symptoms are a washer that will fill and drain, but will not agitate or spin. A loud noise is also common as the the drive motor still spins, but the transmission will not be engaged. This is a very simple problem to fix and does not cost that much to repair. The following link explains:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
A replacement coupling can be purchased on line at any of the following websites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The first three sites also include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The part number is included in the link I provided.
NOTE: The new couplers are reinforced with with a steel grommet to resist breakage better, but they still aren't break proof. Overloading the washer can contribute to premature wear on the coupler and reduce its life span. Always follow the manufacturer's recommendations for properly loading your washer.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 25, 2011 | Roper RAX4233PQ Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Ge top loader washer agitator does not work
Nov 27, 2008 | Kenmore 22422 Top Load Washer
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
GE Washer top-loader
There's no reset button. Pull the front off and check that the belt is still on. In early versions of that little darling the clutch would fall off taking the belt with it. Get back to me
Feb 07, 2008 | GE WWSR3090TWW
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
