Question about Frigidaire Refrigerators
My frigidaire model FRS24zrh is not cooling, what could be the problem?
2 Suggested Answers
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
Frigidaire refrigerator wont cool or freeze
Hi Teddy,
It's my understanding that your Frigidaire refrigerator, model# MRS20WRGW2, has power with the lights coming on, it's just not cooling in the freezer or refrigerator portion. Since you are receiving power to the appliance, I would check to see if you can hear the compressor running. If the compressor is not running that might be why your refrigerator is not cooling. Still, I would contact a local authorized technician, for a full diagnosis. This way it can be determined what exactly is the cause of the NO COOL issue.
-Best Regards-
WP
Apr 04, 2014 | Frigidaire Refrigerators
FRS24ZRH replacing defrost timer
The 215846602 Defrost Timer for your model is found behind the kick plate grill at the bottom of the front of your refrigerator. Location number 23 in this PHOTO HERE I am here should you have questions, Thanks Sea Breeze
May 26, 2013 | Frigidaire Refrigerators
My FRS24ZRH refrigerator quit making ice. How do I determine what is wrong?
Either your inlet valve is bad or your icemaker is bad. Change the inlet valve first it's cheaper. It is located in back behind the screw off panel. It is the object that your water line is connected to. Hope I helped. Also make sure your freezer did not freeze up the tube up top behind icemaker. If you don't check that your inlet valve still won't work with a tube of ice in the way of the water. Good luck. Rate me if I helped.
Aug 22, 2010 | Frigidaire Refrigerators
I have a frigidaire model FRS24ZRH side by side ....about a 2000 model, and we keep finding puddles of water coming from underneath it. This unit also has frozen ice in the bottom of the freezer, I can...
Good day,
Assuming the temperatures in the machine are normal.
Your drain system is either iced or frozen.
Machine must be off to perform the following.
In the freezer compartment, remove the bottom back panel. Remove what ice you can but use little heat, and no chipping. Real hot water, and lots of towels are best.
Once you get the ice melted out, you will see a hole, below the cooling coil that drains the water to the drain pan. Keep pouring extremely hot water into the hole to see if it will open. If not,
Service techs use compressed air with a hose, to blow the drain open, backward. From the drain hose at the drain pan back into the freezer compartment.
If you have access do as the pros do, but if not, repeated use of an extremely hot water with a weak solution of bleach may get the job done.
I use a tire pump with a 1/4 inch fitting on the end to clear drains,
In either case that will have to be done.
Do not rush this process. Time is your friend here.
Once done, make sure you don't see ice streaks running down the coil. The ice maker fill tube can cause this problem, if it is dislodged.
Should solve the puddles of water on the floor as well.
Thank you for using FixYa
Jan 17, 2010 | Maytag MSD2758G Side by Side Refrigerator
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
FRS24zrh Side by Side Fridge was not cool enough then freezer started warming up, defrosted everything, vacuumed underneath, worked fine for about 12 hours and now seems to be warming again
I had the same sort of problem. Found that the freezer would not completely defrost on each defrost cycle. Replaced the defrost thermostat and solved the problem.
Hope this helps.
Jul 23, 2008 | Frigidaire Refrigerators
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Dec 09, 2007 | Frigidaire Refrigerators
Refrigerators Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
