Question about Water Heaters
How to replace thermal fuse redring ws7 water heater
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: I have an atwood g6a-7e water heater. The thermal fuse is bad. i need to know what temp and coltage the thermal fuse for this heater is. The numbers on the fuse do not mach any thing on the web.
ANy RV dealer should stock that item . You can temporarily by-pass it for use but be aware you have no safety should a flame-up happen due to spider webs etc getting in to burner tube.
Posted on Sep 14, 2012
We're is the fuse located for the electric water heater I have hot water on gas but the electric heater just stopped when I'm plugged in
It is not fused, they don't use fuses and haven't for decades, it is hooked into the house current at the breaker box for the house.
Jul 21, 2016 | Water Water Heaters
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
Looking for a fuse or reset button on my Boilermate water heater?
There are thermal fuses and they are not resetable. The problem could be that the heater coil is burned out. If you dont know anything about testing them, you should call someone because you are dealing with high voltage and water.
Sep 09, 2013 | Water Heaters
Sep 13, 2012 | RTO Atwood Water Heater - 6 Gal LP
Reliance gas water heater 640ycrs pilot light will not stay after 1 heat period replaced thermal couple has gas thermal switch
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Mar 04, 2010 | Reliance & 30 Gal LP Gas Water Heater
Error code 14 shows on the remote for a noritz tankless lpg water heater. what does it mean?
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
Dec 10, 2009 | Noritz 6.3 Gallon Residential Tankless...
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
Water Heaters Logo
265 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
