Question about Aiwa AV-D77 Receiver
Sudden failure to power up
A few days ago my receiver failed to switch on when I hit the "power" button on either the unit face or the remote (the only response I could get was the faint clicking sound the reciever has always made when being switched on). However, after some frustrated repitition, I was able to switch the unit on and for a few days everything was fine. Then again last night the same issue occured. Nothing in the troubleshooting guide comes to close to describing my issue. I know there is power going to the unit, as the red light on the front remains lit as though it were still in Standby. The unit is wired into the same surge protector I've had it on for over a year and every other device plugged into it (TV, Xbox, DVD) works fine.
  • 9 more comments
  • megandy Nov 14, 2007
    I'm having the same problem. I unplugged it once and worked for a few days. After that, it only makes a clicking noise when you press the power button. I tried holding the enter and power. That did nothing.
  • Anonymous Jan 08, 2008
    lo mismo
  • lymie Mar 03, 2008
    will not power up
  • Anonymous Mar 27, 2008
    lo mismo que los anteriores
  • nboller May 29, 2008
    mi receiver cuando lo intento encender se apaga en seƱal de proteccion.algo similar a lo del amigo smud.se enciende la luz roja de la parte frontal.ella funcionaba perfecto hasta ayer que se me *** este problema.soy jose guerrero desde caracas venezuela.
  • reno 2 Aug 06, 2008
    im also having the same problem of not powering up. tried to reset and that didnt work.
  • kim_markus Aug 20, 2008
    put in usb stick and was just frozen after alittle bit left to go and just stayed there than it said don't power off so I waited for a good hour and than took the stick out and there was nothing so I shut the back off quickly and turned it back on now there is nothing,what is wrong?
  • Anonymous Sep 05, 2008
    I looked through the book and tried the power button then hit enter to erase the previous programing. The
  • mgrowen Sep 05, 2008
    I went thru the procedure like on page 7 of the instruction manual to turn off the eco mode. All it does is click, and do nothing. There is power to the receiver because the small red light to indicate eco mode is lit in the front.
  • aheck Sep 11, 2008
    My Rx will not turn on It has had hard use as my handicapped wife puts many hours on it. It was intermittent for a long time but finally quit. I hear the relay click and check the ac voltage going through it. It is momentary (the top board on the Power supply) Is this supposed to latch? I also hear another relay clicking but not sure which one. Does anyone have a schematic? Thanks for any help you might be able to give.
  • clue Nov 08, 2008
    same issue. Tried to clear the memory using the power-enter buttons... didn't work. Hate to generate another piece of trash if it is a simple change of a transistor or a latching relay... Please help.
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Posted on Mar 22, 2007
I have the same problem with the same negative results. Any ideas?
Posted on Dec 11, 2007
The sound cut off all of a sudden and I now can't get any mode to work
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired no problem.
May 11, 2016 | Yamaha RX-V665 Receiver
Hisense LED HDTV
I am no expert, but I would be looking for a replacement or warranty on that unit.
Unfortunately there is very little an every day user can do to fix a problem like this on their own.
Jan 29, 2014 | Televison & Video
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
We have a dell monitor/tv and the remote control wouldn't work all of a sudden. when we tried to fix the problem, somehow we "locked the buttons" and cannot figure out how to unlock it.
Email Dell tech. support with your issue.
But first try removing the power cord and press and hold the power button on the front face of the unit for 30 seconds..
Remove the battery on the remote and press any key on the remote for a few seconds.
Replace the batterys on the remote and power cord on the Monitor.
Try to power up the unit and see if that works.
The Monitor/TV have a CMOS battery which retains all your setup information. By removing the power and holding the power button, you may be able to clear the memory and reset the unit.
Sep 06, 2009 | Dell Computers & Internet
I have Crown Tobago boiler that cut off two days ago
Possibly due to a power failure, control unit needs to be reset. Hit reset button. Hold for 30 seconds. Also no fire typically due to nozzle clogged, no fuel which means control will shut down. Water in fuel will also shut boiler down. Clogged filter will decrease fuel flow. Electric eye face is dirty which will also shut it down. If you have a two line system, open up bleeder and see if you get a good flow. Check electrodes for burned ends or out of gap specs.
Aug 04, 2009 | Water Heaters
Trouble turning on the tv at times
The next time I try to turn the unit on the remote will not work or I can not turn the unit on with the switch on the side.
This statement leads me to believe the IR receiver and associated set-top button circuit may be at fault.
If you haven't hammered the set to pieces yet, try this; next time it fails to respond to the remote, put the remote in your freezer for 2-5 minutes (not longer, the batteries won't appreciate it) and then try it again.
If it then functions normally, then a certain integrated circuit (PT2222 or PT2221) may be from the same lot as mine and is abnormally sensitive to warmth. If this does make a difference, try removing the battery compartment cover and intentionally leave the remote face down.
If these tests don't seem to make any difference to the remote, then it is likely that the receiver end in the set is faulty.
Jan 27, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
Failure to Warm Up
Failure to warm would suggest the fuser unit is failing and the machine is failing to reach the temperature that toner melts and fuses to the paper. The machine should display error 76 or 77.
Try this ONCE only!! till the after 99 bit. Hit menu, *,2,8,6,4 quickly if all the button flash and maintenance is displayed enter 99. Now if the error reoccurs you need to replace your fuser unit as it failed as opposed to just malfunctioned.
It will melt if there is a problem and you keep repeating this process. So please only once. If it takes you a few goes to get into maintenance modes its ok but the reset of 99 do only once.
Mar 02, 2008 | Brother IntelliFax-2820 Laser Fax
Remote does not work
Do the buttons on the front panel of the unit work?
If so, try doing this:
Hit the tivo button, go down to messages and setup and into to system information. Go down a few screens until you see remote code. Hold (on your remote) the tivo button and pause button for about 5 seconds. Then hit 0-9 on your remote to set the code. It's a single digit code only. You'll see your remote light flash. Now, try hitting the back button and see if your remote works. If it does, great. If it doesn't that means one or more of the following:
1) Your remote is defective
2) Your IR receiver on the unit isn't working correctly.
If #2 is the problem, you'll need to open up the unit, powered down! and make sure the thin, greyish ribbon cable in the front of the motherboard is 100% in. If it's not all the way in, it will cause issues.
Nov 20, 2007 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Aiwa AV-D77 Receiver Logo
821 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
