Question about Ricoh Aficio Office Equipment & Supplies
Can I change the drum units for my Ricoh 2238C myself or should I call a technician?
  • Nancy Godfrey Feb 08, 2012
    I know what it needs to eliminate the black line on my copies; it needs a new drum for the black. I am hoping it is an easy replacement that someone could walk me through it. If not, I will have to spend the extra money for a service guy to come. I hate to do that if it is not necessary.
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Posted on Apr 07, 2009
  • 6 Answers
SOURCE: Ricoh 2238c prints white spots all over the page
Sounds like you need a new dev unit or drum possilbly both.When was it last serviced?
Posted on Nov 17, 2009
Testimonial: "Thank you problem solved. Changed both and works like new."
tessabilisim
  • 9 Answers
SOURCE: ON a Ricoh Aficio 2238c what is error code
393-004: M magenta td sensor error
Loose cable
connection
• Positioning plate out
of place
• Defective TD sensor
• Development unit not found
2. Check that the development unit is
correctly installed.
3. Remove the development unit and
check the connector on the rear.
4. Check the positioning plate.
5. Replace the development unit.
kendine iyi bak :))
Posted on Nov 24, 2009
john504
  • 31 Answers
SOURCE: Can i change the DQ-UHS30 drum unit into DP-C354
Most Likely a Tech.
Order your drum unit from PrecisionRoller.com then look at it to see if you can do it yourself. I'm a Canon guy but I think that on this machine it's not to bad. Open your front door on the machine and look it over. There may be some plugs to unplug etc.
Posted on Jun 09, 2010
SOURCE: our ricoh aficio appears an
en allumant mon photocopieuse, après 5seconde la lettre sc500 s'affiche et ne fonctionne pas
Posted on Aug 09, 2011
My ricoh printer stoped printing and came up with an error code sc440-01
Possible Drum motor, or sensor - you would do best getting a professional in to repair, as self repair on these will no doubt end in issues..
Aug 28, 2014 | Ricoh Aficio 2238C Color Copier Printer
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
ON a Ricoh Aficio 2238c what is error code sc393-04
Loose cable
connection
of place
kendine iyi bak :))
Nov 23, 2009 | Ricoh Office Equipment & Supplies
Ever since we changed our fuser oil on our ricoh 2238c the paper is getting jammed and we have stopped that by rerouting the printer to the external tray but we can no longer print duplex any solutions and...
If it's only happened since you replaced the fuser oil, maybe something isn't sitting in there correctly. Try removing the oil supply unit and fusing unit and then reinstalling them.
Sep 24, 2009 | Ricoh Aficio CL7000 Laser Printer
Apr 06, 2009 | Ricoh Office Equipment & Supplies
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
225 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
