Question about Huffy 26 in. Cranbrook Cruiser Bike
I cant remove my bike pedals
They are frozen and wont budge
Frozenbike pedals are not a problem if you follow a few simple steps. To begin with,the Right Pedal is standard, and the Left Pedal is Reverse Thread. If you areturning the wrong way, they will never come off. The trick is to use thecorrect wrench, skinny enough to slide in place without slop, and try toposition the wrench next to the Crank Arm in such a way that you can squeezethe Pedal Arm and Wrench together as if giving a very firm hand shake. Justsqueeze hard, and 90% of the time it will break free. If it doesn't, then sprayWD-40 or some other penetrating lubricant on both sides of the threads takingcare not to contaminate the grease inside the pedal bearings. You might have togive it a good soak, and bang the metal crank arm several times to make thelubricate work its way into the thread, sometimes leaving it for 24-hours canmake easy removal the next day. Remember, the Right Pedal is Right, and theLeft Pedal is Reverse, meaning, the Right Pedal tightens normally in theclockwise direction, and loosens in the counter-clockwise direction. The Rightpedal is from the Bike Riders perspective, when sitting on the bike, the Rightpedal is on the Right Side. An extension pipe can be slipped over the wrenchextending its length 2 or 3 feet, and will bust free just about anything frozentogether, however such a method risks damage, and you might end up needing toreplace the Crank Arm.
Posted on Apr 20, 2012
Serger wont budge..hums when step on foot pedal
Motor is locked down. Do Not Energize! take to factory certified service repair person. You will burn up motor or even worse "start a fire" if you try to run it. something is binding motor, this could be many different things.
Nov 08, 2015 | Singer 14SH654
How do i remove forks from K 75S I981 B.M.W. motor bike. everything is undone . wont budge .
With everything undone use a rubber or plastic mallet to slide the forks out
May 29, 2014 | BMW K 75 S Motorcycles
Quad bike kick start wont budge
This maybe a transmission or engine locked up.
Feb 28, 2014 | Yamaha Motorcycles
Hi im having ploblems removeing the right adapter on the pedal chainweel it is solid and will not budge.any suggestions. thanks steve.
Place the unit in a cold location , metal contracts. then put your spanner on the bike and wrap chainwheel in an old rag. Tap the spanner with a piece of wood and a hammer
Should work for you
Dec 06, 2010 | Mongoose 2008 Amasa Comp Mountain Bike
I have a Honda CB600, the front fork is stuck inside the slider?
Your bike probably has a recessed bolt at the bottom of the fork that holds the inner stem. Remove it and the stem should come free. Go to www.babbittsonline.com/partspviewby brand/parts.aspx to see an exploded parts diagram of your bike.
Feb 04, 2010 | 1998 Honda CB 600 Hornet F
Pd -m424 cant get pedals off bike? do i need to use allen key as well as spanner
No, you do not need to use both. In fact, you should never use a spanner wrench to remove your pedals or anything requiring large amounts of torque. For removing your pedals you should be using an pedal wrench or if the pedals are not very tight the allen wrench. A basic pedal wrench like the Park PW-5 is inexpensive and does a great job. Also remember that the non-drive side(left) is reverse threads, meaning both sides come off by unthreading to the rear of the bike.
Hope this helps. Thank you
Jul 15, 2009 | Shimano M324 Clipless Spd Platform Pedals
Frozen Boot Lock Peugeot 106
You can spray solvent into the lock...Do it several times and use the nozzle extension to really get in there. If that does not work, you will need to remove rear seat and use long extensions to unbolt lock from lid.
Mar 18, 2009 | 1991 Peugeot 405
Huffy 26 in. Cranbrook Cruiser Bike Logo
340 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
