Question about Avermedia AVerDiGi EB1304 Net
AverMedia AverDigi - HDD Not Detected
Hi there. This product had been reporting "HDD Not Detected" I have since opened it up and replaced the 500g SATA Seagate HDD with another (brand new) HDD. I am still receiving the same error message! Any suggestions would be appreciated!
DVR Cplete Hung & freez
sounds like a software problem. could be on Windows or on the NVR software. best bet is to re-install windows formatting the hdd completely. once done re-install the NVR software. if that does not solve your problem have a look at the graphics cards in the unit as well as the hdd. they could be faulty.
Dec 09, 2013 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Remote contol does.'t work
There's not much to go on here, but lets start with the simple things first. Check the following:
1) Batteries (be sure that they are in correctly)
2) Use a camera and look at hte remote while puching a button, you should see something in the camera.
3) If you have experience with TVs, open up the unit and check the infra-red receiver. Quite often the solder connections for these go bad which will generate enough noise to cause it to fail.
Check these and update this with your progress.
Good luck,
Dan
Oct 08, 2012 | Avermedia AVerDiGi EB1304 Net
My hitachi hard drive Hitachi HDT721064SLA380 isn't detected by computer and i can here a sound "tic tic" in the HDD ,Thanks .
Hi Welcome to Fixya!
Your hdd is making that sound mainly because it could already be damaged inside. That is also the reason why it is not being detected by the computer.
Same thing happened to me with my 120gb Seagate Barracuda.
Consider in replacing the hard drive on your computer.
Hope this could help!
Have a great day!
Jun 30, 2011 | Hitachi Deskstar 7K1000.B HDT721064SLA380...
Where can i order a hanheld remote control
I am also missing the remote for this DVR that is on a repair job and I can't get passed the prompt for the remote to resetup the DVR not sure wht the price is 5-7 day lead time first solution others may follow.
http://www.basscomputers.com/itemdesc.asp?ic=DV04S120A3&eq=&Tp=
var isMac = (navigator.userAgent.toUpperCase().indexOf("MAC") != -1) if(!isMac) { var newImage = new Image(); newImage.src = "/mmSHOP/images/DV04S120A3.jpg"; } dv04s120a3-100.gif List Price: Log In Qty: buy_now.gif Item Code: DV04S120A3 Weight: 0.20LB Brands: AVERMEDIA Stock: 1 Model: ZACCMSNVD0 Categories: SECURITY - DVR STANDALONE Warranty: 30 DAYS Condition: BULK Lead Time: 5 to 7 Days
Dec 20, 2010 | Avermedia AVerDiGi EB1304 Net
Hi i am looking for some help and advise with the setup of the dvr box eb1304net sata. i have succesfully set up the ddns and it is set to stanley.avers.com.tw , i have also set up the dvr viewer on my PC...
You have a problem in use the same port(80) in router and also the dvr.Try change the port of the dvr to something diferent like 5550 and open this port on the router.
Nov 16, 2010 | Avermedia AVerDiGi EB1304 Net
Drivers
http://www.avermedia-usa.com//AVerTV/Product/ProductList.aspx?IID=7
Jul 12, 2010 | Avermedia M150 (MMCEM150B) Video Capture
Remote is not working
The most likely cause is a problem with the hand held remote. These units use infrared light which the eye can not see. But if you have a digital camera it can! Look at the remote through the view screen of the camera while someone pushes buttons pointing at you. If it is working you'll see a pulsing light. if not change the batteries or try a universal remote.
May 08, 2010 | Avermedia AVerDiGi EB1304 Net
Avermedia AVerDiGi EB1304 Net Logo
145 people viewed this question
Top Avermedia Televison & Video Experts
Vernon Taylor
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
