Replacing bios on non booting eMachines 350 21G16i
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: emachine sp2 prob
BIOS is unlikely to fail from a software fix such as SP2 but you may have too little ram or too slow of a processor to handle changes.
You may have to do a complete reinstallation of XP to set things right and then try the SP2 upgrade again.
Windows is unfortunately sometimes infuriatingly cranky and may require repeated installation before settling down.
Also, eMachines may have tweaked their version of XP in a way not compatible with SP2.
Check their website or MS Knowledge Base for clues.
Posted on Apr 29, 2008
  • 160 Answers
SOURCE: eMachines 350-21G16I Netbook bluetooth driver
Hi
Go to http://www.emachines.com/support/drivers.html. Here you have to choose your product family, line and model. So you will choose Netbook, Netbooks and 350 and the drivers will appear below. Click on the circle with the downward arrow to download
Please comment if you have any questions at all
Posted on Jan 15, 2011
  • 6 Answers
SOURCE: Unfortunately I have broken emachine 350-21G16i
Yes.
First check the cable bus from the motherboard to the screen to see if that is not damaged.
Posted on Mar 18, 2011
  • 86 Answers
is this from a fresh instal?
Posted on Jul 30, 2012
Could anyone tell me the bios boot order for a
I would recommend just booting to your bios and checking. Just press F10 when your computer boots up and look for the boot order under the Bios. Since there are several BIOS options out there check under "System Settings" first I believe. Sorry I havn't touched a EMachine in 10 years.
Oct 07, 2014 | Computers & Internet
Default boot order for emachine laptop 732
Step 1:
All computer systems go through a set of instructions called the Basic Input/Output System (BIOS) when they are turned on. The BIOS checks all of the hardware and software installed on the computer to make sure they are working properly before loading the operating system. You may need to access the BIOS menu periodically to find out the current version of the BIOS you have if there are upgrades available. The command you use to access the BIOS settings on an Emachines computer will vary depending on the specific model you have.
Access the Start menu and click "Shut Down." Select the "Restart" option. Wait for the Emachines logo to appear on the screen as the computer begins booting up again. Press the "Tab" key when the logo appears and see if the computer switches to the BIOS menu. Press the "Escape," "Delete," or "F2" keys if the "Tab" key doesn't take you to the BIOS menu screen. Use the right arrow key to highlight the "Main" entry and press Enter. Scroll down to the heading labeled "BIOS version." Check the long string of numbers and letters under the "BIOS version" heading to locate the current BIOS version your Emachines is using. Press the "F10" key to exit the BIOS menu screen and finish booting up the computer's operating system.
Access/Enter Motherboard BIOS http://michaelstevenstech.com/bios_manufacturer.htm
Feb 22, 2013 | eMachines Computers & Internet
Replacing battery
the battery is on the motherboard, it's a small round silver battery, just pop it out and replace. you shouldn't need to save your bios settings. when you put the new battery in. you don't need to do anything apart from taking old battery out and putting new one in.
Sep 30, 2012 | eMachines Computers & Internet
How to reset bios emachine d 725
While computer is booting you will be prompted with a message saying Press( ) to enter setup/bios the hot key will be one of the following. F1, F2, DEL, ESC, or F10. After that its as simple as choosing reset to default.
If bios has a password which is keeping you from getting in, take off the computers side panel. Locate the watch battery, and remove it. Leave it out for 20 mins before replacing. Start up your computer, and you should be good to go.
Aug 15, 2011 | E-Machines eMachines Desktop PC
My e-machine w3410 gives me a disk boot error insert disk and hit enter what does that mean
You probably have a non-bootable disc in the CD drive - when the computer powers up, your BIOS's first boot device is probably the CD drive and since it has a non-bootable disc in it, it can't boot. Remove the disc and re-boot your computer.
Dec 22, 2010 | E-Machines eMachines Desktop PC
Old emachine T2642 will not boot...disk monitor LED stays on and CPU fan does not rotate...no boot access to CD-ROM, or disk drives...changed power supply...think it might be BIOS backup battery...
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Dec 20, 2008 | E-Machines T2642 PC Desktop
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Emachine sp2 prob
Apr 29, 2008 | Computers & Internet
Bios
Replace the CMOS battery that is busted. after replacing configure in bios setup and load bios setup default.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
