Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
93 chevy truck runs then when warm it stall and wont start till its cool
  • 5,370 Answers
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Posted on Mar 03, 2012
What is causing my 93 mark 8 to stall at idle
I had a problem with both the speedometer and odometer in a Lincoln. It may also have an effect on the engine operation. My speedometer showed 45mph standing still and miles were rolling up on the odometer.
For me, it was a bad Alternator. The alternator was shorting out through the case. You should have your alternator checked and if you find out it is good, then the problem is something that is charging the car body.
You are getting a stray current that is messing up your dash and engine controls. You may have a power wire which rubbed through its insulation.
Mar 27, 2014 | 1993 Lincoln Mark VIII
2000 suzuki vitara runs 15 min stalls wont start till cools down
Did they figure out if you are loosing fuel or spark when it fails to start up ? You would need to know which to proceed.
Feb 13, 2014 | Suzuki Grand Vitara Cars & Trucks
1998 cherokee stall when driving and gets warm ,And wont start till it cools off ?
does your temp gage seem off does it go like up to the h because if it does you could try unpluging your upper coolent sensor because that could cause that because it is telling you computer to run in closed loop when it should be running in open loop
Aug 07, 2012 | 1998 Jeep Cherokee
93 cutlass runs very bad untill i unplug any sensor on the engine then it runs better but when it warms up sometimes it wont start till it cools down
there may be a short to ground somewhere and the pcm readings are off the chart.it sounds like the ecu/pcm is bugging out.
Mar 18, 2011 | 1993 Oldsmobile Cutlass Ciera
I have a 93 accord lx it starts right up when the engine is cold but after you drive it and it warms up it wont start up till it cools down. i'm thinkin its a problem in the distributor. any ideas?
Have your main power relay checked. It seems to fail when the car warms up and then starts to work again when the car is allowed to cool down.
Jan 06, 2011 | 1998 Honda Accord
93 Dodge Shadow 2.2l started having issue of running then dying, replaced fuel pump and filter. Car ran till warm up, shut it down to clean up for a test drive, stalled and now wont start, cranks but no...
I would look for spark, you may have an ignition problem. it would be a sensor that goes into your distributor, the plug should be a round one with i believe 4 wires.
Oct 29, 2010 | 1993 Dodge Shadow
2000 silvarado 5.3 vortech runs good for awhile after it gets hot it shuts off and wont crank until it cools off
do you mean wont crank over and start till it cools off? if thats the case it sounds like you got a bad crankshaft position sensor,,thge sensor is fine when its cold and warm but when it gets hot it goes open and the cars computer cant see the rpm and shuts the engine off,and then when it cools off the sensor works again and the car starts and is ok till it gets hot again,if thats the case thats what it is,,,hope this helps,,,about $100 for the part
Oct 07, 2009 | 1985 Chevrolet Chevy
93 chevy lumina euro won't stay running
if you can check for spark when it wont start and fuel pressure and the service port , would be great information , otherwise pattern failure is ignition module and crank sensor (replace them as a set) , after cools off it will run again.
Dec 31, 2008 | 1993 Chevrolet Lumina
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
279 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
baire
john h
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
