Radiator furthest from boiler not getting completely hot only flow pipe hot , return pipe cold
  • 417 Answers
This could be as a result of air in the radiator, most radiators have an air expulsion screw at the top of the radiator one one side. You need to undo this screw and release the air until some water appears then close the screw and turn on the heating to test. NB Do not attempt this with the heating on. Also you may need a special type of key to open the screw these are available from diy stores or plumbers merchants.
Please remember to rate this article.
Posted on Oct 22, 2008
All radiators cold
you need to re bleed the system. starting at the end radiator. one furthest away from the boiler. and work your way back. re filling the system put air in to the system and you need to get it out. pressure should also be a 1.5 to 3 bars for a good flow in the system. also make sure all the flow taps are open when doing this bleeding or you can trap air in the line.
Jan 19, 2014 | Cars & Trucks
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
What is the best way to purge a hot water baseboard heating system?I seem to have a lot of air and system seems to be not flowing at all
The answer to your question depends on the design of your heating system. There are two common piping arrangements. The first is called a Venturi system. In this type of system you have a main loop that runs around the house with "scoop" tee's that force the water through each radiator/baseboard in the loop. With this type of system you must bleed each radiator individually. At the end of each radiator you should find a bleeder that will require either a flat head screwdriver or a square "key" (available at the big box hardware stores) to open the valve and bleed. This can be a somewhat time consuming process as to do it correctly you must go around the entire loop (preferably in the order of flow) 3 or 4 times to ensure you have moved all the air out of the system.
The next type of arrangement is know as a standard loop. This is where the water flows from one baseboard to the next, in a loop. (ie the baseboards are connected to each other, not just pulled off a common loop). In this type of a system you should find a "stop and purge" set up at the boiler. There should be a valve on the return close to the boiler, and just above that a boiler drain. (faucet type fixture). If you close this valve, connect a hose to the boiler drain and let the water flow into a bucket, you will be bleeding the hot water loop. If you have more than one zone, you will want to close all the valves at the return, and bleed each zone out indiviadually. After all zones have been bled, you can then re-open the valves.
As a note, you should see a water feeder located on the piping going into the boiler. (This device is connected to the cold water line that feeds all your household fixtures. ie sink, tub, etc) If you move the lever to the fast fill position it will allow water to flow into the boiler at a much faster rate, thus helping you push the air out easier. This is only really possible with the Standard Loop layout, because you need to monitor the boiler pressure anytime it is "fast filling". If you are "fast filling" you MUST ensure to release the lever prior to closing the boiler drains or you run the risk of causing the pressure relief valve to open, which can and will cause personal injury and property damage.
Hope this helps
Mar 03, 2012 | Jeep Grand Cherokee Cars & Trucks
I have a vaillant ecotec plus 630r1 system boiler, since two weeks ago the central heating part of it is causing problems. Even when i put the heating dial on max most of the rads would not get hot and...
You either have a bad circulating pump or you have air in the system. A little bit of air can completely stop water flow in a boiler system. Your problem is more than likely air though. Each radiator should have an air bleed on it. Turn your boiler completely off. Go to each radiator and open the air bleed. It will be located towards the top of the radiator. After air is bled out, close the air bleed and go to the next one until all have been done. If you have a two story house, start at the lowest level of radiators. When you are finished start the boiler back up and let it run for about 2 to 3 minutes and shut it back down and bleed all the radiators again. If you are making progress and getting more to heat up but not all of them yet, keep repeating process until all of them heat up.
Jan 30, 2011 | Heating & Cooling
The hot water in my flat is supplied by a communial boiler. Recently, the water in the cylinder was not heating the water as efficiently as it should; the pipe flow from the boiler is very hot, the...
Hello my name is Heath it will be my pleasure to assist you. If the valve is built up with calcium and other water sediments it may seem like the valve is open with very minimal water flowing through the valve Have them replace the vvalve.
Oct 10, 2010 | Heating & Cooling
Which is the cold water input to the worester 240 combi boiler . because of the position its difficult to check . Im fitting a hydroflow limescale reducer .from left to right there are 5 pipes is the cold...
HI turn the boiler on to heating and see which pipe gets hot that will be your heating flow the return will be cold at first , then put on hot water only, pipe to hot taps will get hot , water inlet will get cold , you should be able to work it out from that the middle could well be the gas ?
Jan 30, 2010 | Heating & Cooling
How to connect radiators to the pipes
I am assuming that the radiators you want to hook up are designed for hot water? If so you will need to run two pipes to each radiator, one for supply water one for return. Radiators work well on a monoflow Tee installation ( I suggest you Google monoflow tee intstallation). Valve the supply side so you have some adjustment of water flow to regulate the amount of heat it will put out. From your boiler you will need to install a main supply pipe all the way around the perimeter of the house (in the basement). I suggest a 1" diameter copper pipe. Then you will need to locate your radiators. Install a supply tee in the 1" pipe and go up to your radiator with either 1/2" or 3/4" copper pipe. Install a valve in this line to regulate flow. Connect to the radiator using the correct fitting. On the return side, connect to the same diameter pipe as the supply and take that down to a monoflow tee installed in the 1" copper pipe. Make sure you face the tee correctly or you will not get flow thru the radiator. Because there are different methods to connect radiators, this is just a suggestion. Google the net for other suggestions, talk to a heating professional and study prior to installing or it will cost you money and aggravation.
Nov 05, 2009 | Heating & Cooling
Heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Sep 06, 2009 | Water Heaters
RAds don't get hot anymore
rads not heating could be down to old system ie pipework etc and sludge building up. r there any cold spots on rads? when boiler turning off do u mean going to reset? if so could be over heat prob at boiler . there should be a pressure pipe coming from boiler going to outside if its a combi. if this is leaking your expansion vessel might need re charged as this is where the water will be going.
Feb 05, 2009 | Combi Centre DX - Mango
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
