Samsung Plano model cs-29K3MH dont switch on.Green light flickering,after 2 min makes a terrible noise.If unplugged for 30 min and switched on,works for 15min and switch off.WHAT IS THE SOLUTION.
  • 375 Answers
SOURCE: Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
SOURCE: green power on light flickers
I can help if anyone with this problem lives in Anaheim CA.
Posted on Jan 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
  • 13 Answers
SOURCE: PT-50LC13 won't turn on. Will blink green and make a chirp noise
It is the balister not the lamp. Very common problem that Panasonic will not address. Costs over $600 to repair. file a complaint with consumer affairs please.
http://www.consumeraffairs.com/php/a_report.php
Posted on Sep 01, 2009
What is the line transistor number on Samsung Plano 68cm tv model CS-29K3MH
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Power supply section circuit to many popular TVs are given.
Mar 18, 2015 | Samsung Televison & Video
My Samsung LCD smart tv model UN46D6000SF has no picture, and the power light just flickers constantly. I know it's not the compacitors they are in great condition not defective, even when I unplug the...
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
Help !
try unpluging it and wait 5 mins then plug it back in
Feb 23, 2009 | AEG T58840 Dryer Electric
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Feb 22, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Dead samsung 172n power light flickers
Have you checked the power output from the power board? Is it constant and steady? Try reflowing all the joints if you haven't already. Especially transformer and coil joints. Maybe a bad logic board? Do you have spares to try? Does it do this with everything disconnected from the pwr board (switch, logic, inverter)?
Jan 03, 2009 | Samsung SyncMaster 172N 17" LCD Monitor
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
