Question about Goodmans GTVL19W17HDF 19 in. LCD TV
ON SOME CHANNELS I HAVE INTERMITTENT SOUND HOW DO I SOLVE THIS?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
The common problem with digital problems are with the signal. I suggest you get your aerial checked.It should be outside and aligned correctly with a signal meter
Posted on Mar 08, 2012
CR249 sounds noisy
I don't think it's the cartridge, but if you want to replace it to see if it does correct the problem, by all means do. If it doesn't you just have a spare.
Intermittent faults are hard to solve. Some are caused by bad soldering. Most are caused by a faulty semi-conductor - transistor or IC, which sometimes overheats. If the noise starts up after playing the unit for a while, a hot part could be the cause. If the noise is in both channels then the cause is something common to both channels, perhaps the power supply. However some IC's have both channels going into them, so one of them could cause the problem.
A overheating part is easy to find for when the unit is switched off, you can touch the parts inside. This will reveal that a part will be still hot to the touch (don't burn yourself). Some parts will get hot, but anything that's really hot and meant to be will have an heat sink on them. Any part very hot (with no heat sink) to the touch will be faulty no-doubt.
Mar 11, 2014 | Crosley CR249TA Turntable
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
Any idea why on my new sharp 32" lcd tv, all cable channels except 57 & 58 (CNN) work fine, but on these channels the sound goes off and on, like there is a short in the sound. all other tvs and cable work...
If you do not have problems with picture and sound on all the other working channels, then the problem you are having with 57 & 58 cannot be a short. The problem you are having is that those channels will not tune in properly through your tuner and this is why you get intermittent sound when they are trying to tune in. The sound tunes in easier than the picture. You said that you have programmed the channels again and I am assuming you are talking about the autoprogramming mode. Try to program those channels individually by deleting them and then readding them. If you cannot do that then you need to take the tv back since it is new or have warranty service look at your tuner and setup your tuner by making adjustments to it directly. Good luck and God bless.
Jan 22, 2009 | Televison & Video
Radio loosing signal - intermittent. fuzzing sound accross all channels.
turn the RDS on, this will then re tune itself to the signal.
if you have a VW audi or Ford you may need a amplified aerial feed.
Jul 17, 2008 | Car Audio & Video
Intermittent Sound
Check the audio menu and see if you've selected SAP (Second Audio Program) and if so unselect it..
Bill
Jan 18, 2008 | RCA D52W19 52" Rear Projection Television
RCA 36" TV Model F36645YX2 - Scrolls Through All Channels
if you have a soldering iron you can try to desolder the program+ and program- tac switches switch on the tv again and see if it still scrolls if it doesnt scroll through the channels it means that one of the switches is faulty your remote should work once you desoldered the tac switches replace the tac switch
Jul 14, 2007 | RCA F36645 TV
Goodmans GTVL19W17HDF 19 in. LCD TV Logo
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Henry  Thomas
Henry Thomas
Jonathon summesfield
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
