Multifucional hp photosmart c6180 prende y se apaga
Prende y se apaga
  • 100 Answers
SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Posted on Oct 03, 2010
SOURCE: HP Photosmart C6180 won't print
HP C6180
won't make a Document copy...because it won't print in black ...will print in color any time from PC.
rebooted...won't print black in alignment or cleaning modes.
Any ideas?
Posted on Jul 14, 2008
sagarjd
  • 95 Answers
SOURCE: How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Posted on Nov 21, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Posted on Apr 20, 2009
Tengo una Lincoln Mkx 2007 con 69900km y al girar el switch con su llave adecuada prende el candado y se apaga intermitente y da un pitido de aviso bajo el tablero y no enciende regreso el switch a...
Puede ser un modulo que esta malo eso es lo mejor llevar lo al dealer para que lo chequen.
Mira ver si lo puedes llevar a advance auto parts para que te chequen el alternador puede ser que esta mandando mucho voltaje a lo modulos y causa que el systema se apague.
Feb 03, 2015 | 2007 Lincoln MKX
Mi celular pantech 9070 prende y apaga solo
Hard reset the phone. If that doesnt work, then change the battery. Dificil restablecer el telefono. Si eso no funciona, a continuacion, cambiar la bateria.
Apr 02, 2014 | Pantech P9070 burst
Mi tele solo prende y dura un poquito y se apaga
mi vizio se prende y de momento se apaga y se pone ***** ademas no tiene sonido q puedo hacer
Mar 05, 2012 | Vizio L32 32 in. LCD HDTV
Mi televisor se prende y se apaga tiene tres focos en la parte delantera uno dice lam temp power el de powewr parpadea y no se queda fijo que puede ser
mi tv ultravision hitachi prende y se apaga lo desconecto y lo conecto y prende y hace lo mismo y m parpadea la luz roja d temp q sera ?
Dec 09, 2010 | Hitachi UltraVision 55HDS52 Television
Forgot my bios password on a hp 6730s notebook
mi computador a la hora de prender prende y luego se apaga prende y se apaga podrian ayudarme por favor
Nov 10, 2010 | HP Compaq 6730s Notebook
El TV se prende y se apaga inmediatamente ( no se ve nada)
En maracaibo solo hay uno que repara TV, Computadora, y hace Proyecto tiene el doctorado en ing. en electronica y vive serca de tu casa eso si te quita todo el sueldo del mes pero lo repara jajajajajajaja ;)
Feb 04, 2010 | Digimate DGL2700 27 in. LCD Television
SE PRENDE EL CHECK ENGINE Y SOLO SE APAGA CUANDO
dé vuelta a la llave de ignición 40 veces de apagado a encendido
Dec 12, 2009 | 1997 Mercury Villager
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
317 people viewed this question
k24674
