Question about Sony GDM-400PS 19" CRT Monitor
Monitor wont turn on
Sony multiscan 400ps went black while working in application. When computer boots monitor is not responding, amber light blinks every 2 seconds. I bought this computer used in 1999, it was manufactured in 1998 and was refurbished at the time I bought it. I determined the computer hardware is fine as a stand in monitor works in it's place. Can someone tell me if there's anything I can try to get it working? I have very limited electonics training. There have been times when unplugging/plugging this monitor in has enabled it to be turned on. This didn't work this time, however. I also noticed that the power switch seems to be sticking at times. Thanks, Tim
    Top Expert:
  • Sony Master
  • 28,180 Answers
Check with another monitor, you will know where the fault is then.
Posted on Apr 02, 2017
5 Suggested Answers
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Posted on Mar 16, 2007
  • 624 Answers
SOURCE: My monitor says "input ......" and then the screen flashes off.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
  • 48 Answers
SOURCE: screen always bleu
ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Posted on Jan 21, 2008
SOURCE: Sony SDM-HS73 Not Staying On
The problem is with power inverter, usually the capacitors go bad and need to changed, they might be bulged and or leaking. Very cheap fix, less than a buck apiece and an hour with a solder iron. Google it to find more info.
Posted on Feb 20, 2008
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Monitor and Mouse not working
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
Jul 16, 2008 | Dell Dimension 4600 PC Desktop
Screen always bleu
Jan 20, 2008 | Sony GDM-400PS 19" CRT Monitor
Sony Multiscan E400
back light or inverter problem Dont know about repairs though.
May 20, 2007 | Sony CPD E400 19" CRT Monitor
Image center drifts, bad keystone, jiggles
Hello, the repair seems possibble to me. One of common reasons for the above mentioned error can be bad soldering (contact). Ask a pro to do the job for you. If you need more info please advice. Arpi
Mar 22, 2007 | Sony CPD 400PS (White) 19 in.CRT...
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Sony GDM-400PS 19" CRT Monitor Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
