Question about HTC Hero Smartphone
How do I get my phone to show the correct time consistently?
My phone periodically decides to show the incorrect time and stays on the new time schedule until I reboot my phone. Is there anyway to have it consistently show the correct time without having to reboot all the time?
2 Suggested Answers
  • 158 Answers
SOURCE: Incorrect time showing on face clock
in that case... remeber to set your phone into an automatic time and date update. You can find it on the settings menu and there goes.. its done.
Posted on Feb 02, 2009
In my nokia e63 it is saying that incorrect date and time but my date and time is correct
Confirm the month, date, year, & time is correct. If it still shows correct, try power cycling your phone and when it comes back online, confirm the error is gone and you still have the correct date & time.
Jul 31, 2016 | Nokia Cell Phones
Somehow current time has changed and I DON'T KNOW HOW TO RESET
go to the settings of your phone and change the date/time settings according to your time zone
Nov 01, 2012 | LG Cell Phones
I have a 1998 cavalier, we changed the starter twice and the ignition switch as well. The car will crank over three or four times and then the next time it acts like it wants to start it keep cranking even...
Product Safety - Ignition Circuit Thermal Events # 04002 - (02/18/2004)
04002 -- Ignition Circuit Thermal Events
1998 Buck Skylark
1998-2001 Chevrolet Cavalier
1998 Oldsmobile Achieva
1998 Pontiac Grand Am
1998-2001 Pontiac Sunfire
Due to part availability, this recall is being conducted in three phases. Phase 1 will consist of 1998-1999 vehicles, phase 2 will consist of 2000 vehicles; and phase 3 will consist of 2001 vehicles. When sufficient parts are available to notify customers of 2000 and 2001 vehicles, you will be notified and will receive a new initiation report.
Recall - Ignition Circuit DefectCondition
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 1998 model year Buick Skylark; 1998-2001 model year Chevrolet Cavalier; 1998 model year Oldsmobile Achieva; 1998 model year Pontiac Grand Am; and 1998-2001 model year Pontiac Sunfire vehicles. If the engine fails to start and the driver holds the key in the "start" position for an extended period, high current flows through the ignition switch, and sometimes produces enough heat to melt internal switch parts. If the switch is damaged, a fire could occur in the steering column, even with the engine off and the key removed. The fire could spread to the interior of the car, which could injure occupants of the car or cause damage to adjoining structures.
Correction
Aug 29, 2011 | 1998 Chevrolet Cavalier
Apple iphone 3g 4.1version after unlocking one dya is worked properly then showing no service
Turn off you phone and then turn it back on again. If you leave your phone on for extended periods of time the phone for some odd reason decides to lose cell service.
Simply restart your phone and all will be well.
If this does not fix your problem, you will need to take it into the Apple Genius Bar as the logic board may be malfunctioning.
Dec 10, 2010 | Apple iPhone 3G
Where are timing marks on 1985 suzuki rm 250
This is taken verbatim from the Clymer's manual for 81 - 88 rm 125 - 250's. "The ignitiion timing is preset and does not need periodic adjustment. The timing should only need to be checked if the stator assembly has been removed for engine repair or ignition repair." If you did install a new stator, the manual has a picture which shows the rib of the case aligned approximately in the middle of the stator timing mark.If you're still unsure, I would invest in a manual as "If the stator timing mark and the rib are not aligned, ignition timing will be incorrect. Incorrect timing can easily cause serious engine damange as well as lack of performance."
Good Luck
Aug 05, 2010 | Suzuki RM 250 Motorcycles
Time of Calendar display
i think you are confused.
because if the clock is wrong it will show the wrong time every hour.
try this
Jul 26, 2009 | LG Vu CU920 Cellular Phone
Time on Nortel PBX is correct but some phones show incorrect time
Unplug all but one phone (at a time that you wont have incoming calls), Do either Featue **ADMIN (**26464) set the time, then plug in the remaining phones
Mar 04, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Feb 01, 2009 | HTC Touch Diamond Smartphone
Hanging cellphone
Lordson, there might be two reasons of this problem. 1st is defective battery and 2nd one is it's software problem. You have not specified that wether it is getting charge or not? If it is getting charge then your software is OK. it is your battery problem. Batteries of mobile phone consist two things- voltage and ampere capacity(strengh to support perticular device). Try with another good battery then decide to replace it. If u found it not working and stayed jammed then go to nearby technician and he will reflesh your phone with special motorola tools like Smart Clip, Ultima Box etc. Is it fixing your problem...Then vote...
Jan 09, 2008 | Motorola Mobility RAZR V3
Front screen only shows the time
I have had a simular problem with mine and just fixed it. My phone was doing simular things, but it would also sometimes not show the outside display, or half would be upsite down. Also occasionally when I opened the phone I only saw a white screen. **FIX** There is a small ribbon cable that comes from the top half (w/ the screen) and connects into the circuit board in the bottom half (under battery). It came loose which caused all of my problems. If you clean that connection and put the phone back together it should be good as new.
Jun 25, 2007 | Motorola Mobility RAZR V3
HTC Hero Smartphone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
