Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
31 cc Straight shaft/ head won't turn when connected and running
I recently got back from oversea's and my son was using my ryobi. He said that it was working fine and now all of the sudden the trimmer head where the string is at won't turn under power. It sometimes will slightly grab and spin but when it is put under duress it starts to studder and the string winds on the head.
  • 47 Answers
Pull the shat off the engine and check the inner shaft it sounds like its stripped or the theengine side is cracked hope this helps
Posted on Feb 08, 2009
Ryobi plt-2543y engine runs okay but head will not
Ken it sounds like the shaft isn't going in to the spigot on the engine. Make sure that the head is on properly and that the shaft is in the spigot itself. If there has been any movement with the head creeping down slightly the shaft will no longer go into it. Try and straighten the shaft slightly to give a couple of millimeters more to the shaft.
Sep 24, 2013 | Ryobi Garden
2 cycle 31 cc 15" model 705r curved shaft trimmer plus click link weed wacker ..seems to flood,fuel drips from air intake ,after carb adjustments still will not start cant seem to regulate fuel ,checked...
Check the metering diaphram and check valve in the carby.The valve might be leakin and the diaphrm might be hard. do a google on the make of the carby as these are fitted with a few makes manly Zamer but. DONT use compressed air to clean or automotive type carby cleaner all will kill the valve and its not replacable..
Jul 01, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Clutch removal on 31 cc weed eater
Break the engine away from the shaft on the shaft side. I think 4 bolts/screws. Once you have that open you will seethe part that goes over the shaft. To take it off, hold the part with one hand and remove a screw in the center of the part using a #15 TORX screwdriver. Take off the part and under it is the clutch. Good luck...Lee
Sep 05, 2009 | Ryobi Garden
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Jun 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
292 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
