Question about Lexmark X6150 All-In-One InkJet Printer
X2600 printer has EC5 problem - Lexmark X6150 All-In-One InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
The error indicates that there is a short in one if the cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Posted on Feb 09, 2012
Easy if you can read,thanks
Posted on Aug 22, 2012
Lexmark service centre
EC5 means short test detected: short circuit in printhead. The cartridge needs to be replaced.
Oct 29, 2012 | Lexmark X2600 All-In-One InkJet Printer
Cant find sacan button on lexmark x2600
The Lexmark X2600 scan button on the printer operator panel looks like this printmastert_86.jpg.
For more information on how to scan using your model, please refer to the Lexmark X2600 User's Guide.
Oct 16, 2011 | Lexmark X2600 InkJet Printer
What's C 5 E blinking in the printer screen?
The EC5 error code indicates that there is a short in one of your print cartridges. Please follow the steps below to identify and fix the issue:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance.
Oct 10, 2011 | Lexmark X2600 InkJet Printer
Does my lexmark x2600 need a batterie or power cord or does it work of my pc
The Lexmark x2600 requires a power cord to operate. Its power supply assembly is contained within the printer, so the power cord plugs directly into the printer.
For more information, please consult the x2600 User Manual provided here: www.lexmark.com/publications/pdfs/2007/x2600/v12357467_en.pdf
If you found this solution helpful, please leave a positive rating!
Jul 13, 2011 | Lexmark X2600 InkJet Printer
Hi my lexmark x2650 keeps flashing error code ec5, how do i correct this?
The EC5 error code indicates a short has been detected in one of your cartridges. Open the printer and remove both cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover and check for any errors. Open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error to pop up. Or you can try to insert a different known working cartridge to determine if the other is faulty.
May 30, 2011 | Lexmark X2650 All-In-One InkJet Printer
My lexmark x2600 printer wont print where can i get a free manual?
Navigate into this site, you can download free user manual of lexmark x2600..
http://www.retrevo.com/support/Lexmark-X2600-Multifunction-Printers-manual/id/17669bh333/t/2/
Thanks,
Nov 20, 2010 | Lexmark C533DN InkJet Printer
Have a new lexmark x2600 printer and cannot get it
install first the cd installer of the printer...
...do the set up process until they completely finish..
x2600 is compatible to Vista..
Oct 23, 2009 | Lexmark X2600 InkJet Printer
Problem with cartriges
EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
Mar 02, 2009 | Lexmark X2600 InkJet Printer
I have no instructions for DeLonghi EC5.
Go here and scrool down to Product Details to get the manual.
http://www.amazon.com/DeLonghi-EC5-Steam-Driven-Espresso-Cappuccino/dp/B00009RXMQ
Good luck an please Rate FixYa!
Jan 20, 2009 | DeLonghi EC5
Lexmark X6150 All-In-One InkJet Printer Logo
444 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
