Question about Sharp Office Equipment & Supplies
Auto power shut off - how can I disable
The Auto power shut off goes 2 hours max. but i want to disable it totally. is this possible?
  • Doug Feb 07, 2012
    This is for the Sharp SF-2030 copier.
  • Sharp Master
  • 1,294 Answers
Enter in the users mode and reset the auto power mode.
Posted on Feb 08, 2012
I need help. I have a BENQ MP720p projector. For 6 months I changed the lamp (the old one died). I've been using the projector ever since. 2-3 weeks ago a message "your lamp has ~2900 h of use" came. I...
1,Press and hold the Exit button on the projector for 5 seconds to display the total used lamp time.
2,Press Auto on the projector or on the remote control to reset the lamp hour to "0".
Have a good day!
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 04, 2013 | BenQ MP720p Multimedia Projector
2008 dodge charger anti theft disabled car from starting, how do i by pass anti theft to be able to start it
you cant. the wcm which is the wireless control module can not be by passed. it keeps the tipm which is the total intregated power module from allowing the asd auto shut down relay from letting the vehicle start. you have to tow it to a dealer or a shop that has the wi-tech.
Feb 17, 2013 | 2008 Dodge Charger
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Pump shuts off in very hot weather
might have the wrong motor on it, themotor hp and SF sevice facto determin the total HP output of the motor. so say it's a 1hp with a 1.65 sf it's a 1.65 hp motor ..the impeller detrmins the hp needed, it should have numbers and letters on it. welcome to my world fun huh
Jul 10, 2012 | Sta Rite Sta - Rite 2hp Max - E Pro...
Stopped working although power is still going to the fridge, the dials read - freezer 2 C and fridge 14 C...
Shut off fridgge and power on after some 6 hours. If the temperature in freezer goes to below -5( ideal -18) then the system is working fine. If the freezing stops after several hours then it is possible that the thermostat is not working or the auto defrost timer is not shutting off the system,
However is there is no cooling then the compressor or gas pressure is down.
check this out to confirm
Aug 27, 2010 | Microwave Ovens
My dsc hsx-1 zoom lens wont retract from max.
my cam z sony DSC HX1..the problem z when i zoom in(max) the objct i m zoomin doesnt get focusd....when i shoot it the pic z totally blurrd....no matter how mch i try 2 focus with the manual focus option the outcum z da same....
Nov 27, 2009 | Sony Cyber-shot DSC-HX1 Digital Camera
How to set the auto off??
I had same problem. Could not find manual on-line so I tried different techniques. You can reset the auto-off feature to extend the "On" time up to 3 hours max. You do it by (1) placing the control switch in the "Off" position. (2) Simultaneously push the "Hr" and "Min" buttons. The time display will start flashing the hold time. (3) Push the "Hr" button to cycle through the available hold times, 1 - 2  or 3 hours. When set, turn the selector switch momentarily to any other position to finish the programing.
Apr 25, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Dell e228wfp flat panel. periodically goes blank. when i power off the on promp " 1. Auto detect ( Analog signal )" is up . . . just for a moment then screen goes blank.
It's heat related and possibly a backlight issue - mine only does it when the monitor has been powered on for about 2 hours. If I turn it off for an hour, I can get another 2-hour stretch out of it. Happens in self-test mode, so that's the cruncher. It's taken 2 days and many laborious hours on the phone, but Dell is sending me a replacement monitor tomorrow. There are more people with the problem here: http://en.community.dell.com/forums/t/19245356.aspx. Hope you get yours replaced too...
Nov 15, 2008 | Computers & Internet
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
116 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
